upswing can you connect using LTE link monitor and hit the reset button? It should display some text during the boot process. As long as the factory test firmware is installed it should be spitting out accelerometer readings every second or so.
2021-04-12T23:25:01.879Z DEBUG modem << {ù«ûy£oo¹«ëYééa«kékõszóo«»k³óó³=óã{9kiûõËa£ë{jëoó¡ak©o©+)©o©okëû©oaáûoi©s¡¹ié{©¹iéc!©{)é¡s)©o©?k©o¡¹ié{¡?cãó©»)éùc)©o«éié¡k)éoié{©kiëû¡ái©ooiés©oiéû©oaëû©k)©o£¡ié{©?c©o©;ké{ë}}ko-ëiùáããa/ok«yû«
2021-04-12T23:25:01.882Z DEBUG modem << [00:00:00.202,636] [0m<inf> rtc: PCF85063A is initialized![0m
2021-04-12T23:25:01.921Z DEBUG modem << [00:00:00.211,883] [0m<inf> lis2dh: int1 on pin=29[0m
2021-04-12T23:25:01.923Z DEBUG modem << [00:00:00.217,010] [0m<inf> lis2dh: bus=I2C_1 fs=2, odr=0x1 lp_en=0x0 scale=9576[0m
2021-04-12T23:25:01.925Z DEBUG modem << *** Booting Zephyr OS build v2.4.0-ncs2 ***
2021-04-12T23:25:01.926Z DEBUG modem << [00:00:00.238,098] [0m<inf> app: Start of Pyrinas Hub example![0m
2021-04-12T23:25:01.928Z DEBUG modem << [00:00:00.244,262] [0m<inf> app: device is 0x20020350, name is PCF85063A[0m
2021-04-12T23:25:01.936Z DEBUG modem << [00:00:00.252,746] [0m<inf> rtc: mode 0x16[0m
2021-04-12T23:25:01.939Z DEBUG modem << [00:00:00.257,751] [0m<inf> app: Area 0 at 0x0 on W25Q32JV for 33554432 bytes[0m
2021-04-12T23:25:01.946Z DEBUG modem << [00:00:00.265,289] [0m<inf> littlefs: LittleFS version 2.2, disk version 2.0[0m
2021-04-12T23:25:01.958Z DEBUG modem << [00:00:00.273,773] [0m<inf> littlefs: FS at W25Q32JV:0x0 is 8192 0x1000-byte blocks with 512 cycle[0m
2021-04-12T23:25:01.963Z DEBUG modem << [00:00:00.283,172] [0m<inf> littlefs: sizes: rd 16 ; pr 16 ; ca 64 ; la 32[0m
2021-04-12T23:25:01.974Z DEBUG modem << [00:00:00.298,065] [0m<inf> littlefs: /lfs mounted[0m
2021-04-12T23:25:01.980Z DEBUG modem << [00:00:00.303,192] [0m<inf> app: /lfs mount: 0[0m
2021-04-12T23:25:01.995Z DEBUG modem << [00:00:00.312,561] [0m<inf> app: /lfs: bsize = 16 ; frsize = 4096 ; blocks = 8192 ; bfree = 8187[0m
2021-04-12T23:25:02.002Z DEBUG modem << [00:00:00.321,868] [0m<inf> app: Set up button at GPIO_0 pin 12[0m
2021-04-12T23:25:02.010Z DEBUG modem << [00:00:00.332,946] [0m<inf> app: Battery: 2524 mV[0m
2021-04-12T23:25:02.022Z DEBUG modem << [00:00:00.339,080] [0m<inf> app: Set up gpio walker at GPIO_0 pin 24[0m
2021-04-12T23:25:02.025Z DEBUG modem << [00:00:00.344,116] [0m<inf> app: Accel reading: #1 @ 344 ms[0m
2021-04-12T23:25:03.020Z DEBUG modem << [00:00:01.341,033] [0m<inf> app: Accel reading: #2 @ 1341 ms[0m
2021-04-12T23:25:04.016Z DEBUG modem << [00:00:02.337,951] [0m<inf> app: Accel reading: #3 @ 2337 ms[0m
2021-04-12T23:25:05.014Z DEBUG modem << [00:00:03.334,899] [0m<inf> app: Accel reading: #4 @ 3334 ms[0m
2021-04-12T23:25:06.010Z DEBUG modem << [00:00:04.331,848] [0m<inf> app: Accel reading: #5 @ 4331 ms[0m
2021-04-12T23:25:07.007Z DEBUG modem << [00:00:05.328,979] [0m<inf> app: Accel reading: #6 @ 5328 ms[0m
2021-04-12T23:25:08.004Z DEBUG modem << [00:00:06.325,744] [0m<inf> app: Accel reading: #7 @ 6325 ms[0m
2021-04-12T23:25:09.001Z DEBUG modem << [00:00:07.322,753] [0m<inf> app: Accel reading: #8 @ 7322 ms[0m
2021-04-12T23:25:09.998Z DEBUG modem << [00:00:08.319,671] [0m<inf> app: Accel reading: #9 @ 8319 ms[0m
2021-04-12T23:25:10.995Z DEBUG modem << [00:00:09.316,680] [0m<inf> app: Accel reading: #10 @ 9316 ms[0m
2021-04-12T23:25:11.992Z DEBUG modem << [00:00:10.313,598] [0m<inf> app: Accel reading: #11 @ 10313 ms[0m
2021-04-12T23:25:12.989Z DEBUG modem << [00:00:11.310,516] [0m<inf> app: Accel reading: #12 @ 11310 ms[0m
2021-04-12T23:25:13.986Z DEBUG modem << [00:00:12.307,434] [0m<inf> app: Accel reading: #13 @ 12307 ms[0m
2021-04-12T23:25:14.986Z DEBUG modem << [00:00:13.304,443] [0m<inf> app: Accel reading: #14 @ 13304 ms[0m
2021-04-12T23:25:15.980Z DEBUG modem << [00:00:14.301,544] [0m<inf> app: Accel reading: #15 @ 14301 ms[0m
2021-04-12T23:25:16.977Z DEBUG modem << [00:00:15.298,522] [0m<inf> app: Accel reading: #16 @ 15298 ms[0m
2021-04-12T23:25:17.974Z DEBUG modem << [00:00:16.295,562] [0m<inf> app: Accel reading: #17 @ 16295 ms[0m
2021-04-12T23:25:18.971Z DEBUG modem << [00:00:17.292,572] [0m<inf> app: Accel reading: #18 @ 17292 ms[0m
The blue LED should be blinking as well.
