tedhavelka66 is this data you’re trying to get for different “sensor types” on the same chip? The options that are built into Zephyr are pretty extensive:
* @brief Sensor channels.
enum sensor_channel {
/** Acceleration on the X axis, in m/s^2. */
SENSOR_CHAN_ACCEL_X,
/** Acceleration on the Y axis, in m/s^2. */
SENSOR_CHAN_ACCEL_Y,
/** Acceleration on the Z axis, in m/s^2. */
SENSOR_CHAN_ACCEL_Z,
/** Acceleration on the X, Y and Z axes. */
SENSOR_CHAN_ACCEL_XYZ,
/** Angular velocity around the X axis, in radians/s. */
SENSOR_CHAN_GYRO_X,
/** Angular velocity around the Y axis, in radians/s. */
SENSOR_CHAN_GYRO_Y,
/** Angular velocity around the Z axis, in radians/s. */
SENSOR_CHAN_GYRO_Z,
/** Angular velocity around the X, Y and Z axes. */
SENSOR_CHAN_GYRO_XYZ,
/** Magnetic field on the X axis, in Gauss. */
SENSOR_CHAN_MAGN_X,
/** Magnetic field on the Y axis, in Gauss. */
SENSOR_CHAN_MAGN_Y,
/** Magnetic field on the Z axis, in Gauss. */
SENSOR_CHAN_MAGN_Z,
/** Magnetic field on the X, Y and Z axes. */
SENSOR_CHAN_MAGN_XYZ,
/** Device die temperature in degrees Celsius. */
SENSOR_CHAN_DIE_TEMP,
/** Ambient temperature in degrees Celsius. */
SENSOR_CHAN_AMBIENT_TEMP,
/** Pressure in kilopascal. */
SENSOR_CHAN_PRESS,
* Proximity. Adimensional. A value of 1 indicates that an
* object is close.
SENSOR_CHAN_PROX,
/** Humidity, in percent. */
SENSOR_CHAN_HUMIDITY,
/** Illuminance in visible spectrum, in lux. */
SENSOR_CHAN_LIGHT,
/** Illuminance in infra-red spectrum, in lux. */
SENSOR_CHAN_IR,
/** Illuminance in red spectrum, in lux. */
SENSOR_CHAN_RED,
/** Illuminance in green spectrum, in lux. */
SENSOR_CHAN_GREEN,
/** Illuminance in blue spectrum, in lux. */
SENSOR_CHAN_BLUE,
/** Altitude, in meters */
SENSOR_CHAN_ALTITUDE,
/** 1.0 micro-meters Particulate Matter, in ug/m^3 */
SENSOR_CHAN_PM_1_0,
/** 2.5 micro-meters Particulate Matter, in ug/m^3 */
SENSOR_CHAN_PM_2_5,
/** 10 micro-meters Particulate Matter, in ug/m^3 */
SENSOR_CHAN_PM_10,
/** Distance. From sensor to target, in meters */
SENSOR_CHAN_DISTANCE,
/** CO2 level, in parts per million (ppm) **/
SENSOR_CHAN_CO2,
/** VOC level, in parts per billion (ppb) **/
SENSOR_CHAN_VOC,
/** Gas sensor resistance in ohms. */
SENSOR_CHAN_GAS_RES,
/** Voltage, in volts **/
SENSOR_CHAN_VOLTAGE,
/** Current, in amps **/
SENSOR_CHAN_CURRENT,
/** Resistance , in Ohm **/
SENSOR_CHAN_RESISTANCE,
/** Angular rotation, in degrees */
SENSOR_CHAN_ROTATION,
/** Position change on the X axis, in points. */
SENSOR_CHAN_POS_DX,
/** Position change on the Y axis, in points. */
SENSOR_CHAN_POS_DY,
/** Position change on the Z axis, in points. */
SENSOR_CHAN_POS_DZ,
/** Revolutions per minute, in RPM. */
SENSOR_CHAN_RPM,
SENSOR_CHAN_GAUGE_VOLTAGE,
/** Average current, in amps **/
SENSOR_CHAN_GAUGE_AVG_CURRENT,
/** Standy current, in amps **/
SENSOR_CHAN_GAUGE_STDBY_CURRENT,
/** Max load current, in amps **/
SENSOR_CHAN_GAUGE_MAX_LOAD_CURRENT,
/** Gauge temperature **/
SENSOR_CHAN_GAUGE_TEMP,
/** State of charge measurement in % **/
SENSOR_CHAN_GAUGE_STATE_OF_CHARGE,
/** Full Charge Capacity in mAh **/
SENSOR_CHAN_GAUGE_FULL_CHARGE_CAPACITY,
/** Remaining Charge Capacity in mAh **/
SENSOR_CHAN_GAUGE_REMAINING_CHARGE_CAPACITY,
/** Nominal Available Capacity in mAh **/
SENSOR_CHAN_GAUGE_NOM_AVAIL_CAPACITY,
/** Full Available Capacity in mAh **/
SENSOR_CHAN_GAUGE_FULL_AVAIL_CAPACITY,
/** Average power in mW **/
SENSOR_CHAN_GAUGE_AVG_POWER,
/** State of health measurement in % **/
SENSOR_CHAN_GAUGE_STATE_OF_HEALTH,
/** Time to empty in minutes **/
SENSOR_CHAN_GAUGE_TIME_TO_EMPTY,
/** Time to full in minutes **/
SENSOR_CHAN_GAUGE_TIME_TO_FULL,
/** Cycle count (total number of charge/discharge cycles) **/
SENSOR_CHAN_GAUGE_CYCLE_COUNT,
/** Design voltage of cell in V (max voltage)*/
SENSOR_CHAN_GAUGE_DESIGN_VOLTAGE,
/** Desired voltage of cell in V (nominal voltage) */
SENSOR_CHAN_GAUGE_DESIRED_VOLTAGE,
/** Desired charging current in mA */
SENSOR_CHAN_GAUGE_DESIRED_CHARGING_CURRENT,
/** All channels. */
SENSOR_CHAN_ALL,
* Number of all common sensor channels.
SENSOR_CHAN_COMMON_COUNT,
* This and higher values are sensor specific.
* Refer to the sensor header file.
SENSOR_CHAN_PRIV_START = SENSOR_CHAN_COMMON_COUNT,
* Maximum value describing a sensor channel type.
SENSOR_CHAN_MAX = INT16_MAX,
If it’s a different representation of the same value, then you can use the set attribute method to change the “mode” of the device. For instance, I use one attribute to change the output mode from the numerical representation to the “raw” value of the SHTC3 output.
If you’re looking to get multiple readings from the same sensor, you can simply request the same data multiple times.
Hope that helps.
