    jaredwolff You’ll need to use Segger RTT for the particle boards.
    OK thanks for all the help so far Jared, but I need to take a different path here. It seems like at many turns I need to buy another piece of HW or spend a good deal of time learning something I had no interest in. My goal was air quality info to be sent via MQTT. I have gone down so many tangential paths that this is taking too much time.
    jaredwolff By the way here’s a link to getting half of the equation for Zephyr on an Argon:
    Yes…even this article you cited is about replacing the stock firmware with CircuitPython … already saw this and determined, “Nope…don’t want to go down that path.”
    Instead, I am looking at my first idea of using the AQW with an Adafruit Feather (with wifi support) and the Arduino IDE. I just need to understand the AQW interface & API better now.
      meisner Instead, I am looking at my first idea of using the AQW with an Adafruit Feather (with wifi support) and the Arduino IDE. I just need to understand the AQW interface & API better now.
      Got it. Sorry it’s taking longer than expected. I have a Huzzah32 here. Let me see if I can get the AQW code working on it. I’ll likely be able to get it working with Golioth fairly easily if you’re open to using something like that. They have a generous dev tier which is sufficient if you’re doing this for hobby purposes.
      6 days later
      OK…success!
      I have had the AQW running (in the 3D printed enclosure you designed) for most of the day today using the HUZZAH32 and the Arduino IDE. Here’s the project:
      https://github.com/smeisner/AirQualityWing
      Let me know if you have any thoughts. This is the first version of the code, so improvements would be welcomed!! There is a “to do” list at the end of the README as well.
        2 months later
        Just added support for OTA upgrades, OLED display and telnet session for diags to the github project.
        …in case anyone is following along. I have modified STL files to accommodate the display as well, but haven’t uploaded them yet. Coming soon.
