I was able to successfully connect the programmer. When I read the memory it looked different than the example in the documentation as it had an extra green area of memory with stuff (I can provide the memory location if needed). Went ahead and loaded firmware but then realized it was the wrong one (1..2.2) so went back and erased the memory and reloaded 1.1.0 which shows:
%XSYSTEMMODE?
%XSYSTEMMODE: 1,0,1,0
Then I went back to test with various examples I previously had tested and they all had the same issue which is I can’t get into DFU mode. Is there something else I should be doing?
One last item. In the last couple times I’ve tried to re-program using the Programmer App after completing gave me complete white screen from where I couldn’t do anything. Have you seen that?
