Hi cchoi22915, yup the mfw_update sample is for standalone upgrades. (No programmer or dev kit necessary)
jaredwolff Yes that is correct. I am able to run other code successfully (such as AT_Client) Here is the full error log:
PS C:\Users\Chris\OneDrive\Desktop\Test\nfed\samples\mfw_update> python3 update_modem.py mfw_nrf9160_1.2.7.zip COM5 1000000
[Probes.COM5] [ModemUARTDFUProbe] Dll directory is C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64.
[Probes.COM5] [ModemUARTDFUProbe] Find and connect to dfu dll
[Probes.COM5] [ModemUARTDFUProbe] Using DFU dll at C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[Probes.COM5] [ModemUARTDFUProbe] Load library at C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[Probes.COM5] [ModemUARTDFUProbe] GetErrorInfo failed.
[Probes.COM5] [ModemUARTDFUProbe] Failed to load dll at C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[HighLevel] Failed while initializing probe.
[Probes.COM5] b'An error was reported by NRFJPROG DLL: -151 NRFJPROG_SUB_DLL_COULD_NOT_BE_OPENED. \n[Probes.COM5] [ModemUARTDFUProbe] GetErrorInfo failed.\n\textra: [Probes.COM5] [ModemUARTDFUProbe] Failed to load dll at C:\\Users\\Chris\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python310\\site-packages\\pynrfjprog\\lib_x64\\NRFDFU.dll.\n\textra: [HighLevel] Failed while initializing probe.'
  File "C:\Users\Chris\OneDrive\Desktop\Test\nfed\samples\mfw_update\update_modem.py", line 43, in <module>
  File "C:\Users\Chris\OneDrive\Desktop\Test\nfed\samples\mfw_update\update_modem.py", line 25, in run
    with HighLevel.ModemUARTDFUProbe(api, uart, baudrate) as modem_dfu_probe:
  File "C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\HighLevel.py", line 591, in __init__
pynrfjprog.APIError.APIError: An error was reported by NRFJPROG DLL: -151 NRFJPROG_SUB_DLL_COULD_NOT_BE_OPENED.
        extra: [Probes.COM5] [ModemUARTDFUProbe] Failed to load dll at C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
    I have uninstalled and installed practically everything (even restarting my computer in between). I wonder if there is a way for me to download NRFDFU.dll separately? Although there appears to be a bigger issue at hand
    That is one thing I have not tried downgrading yet. I am currently creating an Ubuntu VM to see if it is an OS related issue. I will try to downgrade python and also try Linux to see how this fairs.
      4 days later
      jaredwolff Whoops, forgot to update this thread, but the issue continued to occur when I tried this in Linux. I was, however, able to follow the steps in LINK TO FORUM PAGE and successfully update the modem firmware.
