Can I use the same merged.hex generated from the example app template in order to program an nrf9160 on a custom board? I have successfully connected to the custom board and used nrfjprog to program and verify the .hex image. The issue is no UART is output on pins 0 and 1. The same code runs successfully on the feather with the same pins.
Thanks,
Chris
