cchoi22915 I’ll try to do a live session on this. It’s straight forward though, especially on the nRF52/91
 * Copyright (c) 2021 Circuit Dojo LLC
 * SPDX-License-Identifier: Apache-2.0
#include <drivers/watchdog.h>
#include <watchdog.h>
#include <logging/log.h>
LOG_MODULE_REGISTER(app_watchdog);
static const struct device *wdt = DEVICE_DT_GET(DT_NODELABEL(wdt0));
static int wdt_channel_id;
int app_watchdog_setup()
	int err;
	if (!device_is_ready(wdt) || wdt == NULL)
		LOG_WRN("Watchdog not ready");
		return -EIO;
	struct wdt_timeout_cfg wdt_config = {
	    /* Reset SoC when watchdog timer expires. */
	    .flags = WDT_FLAG_RESET_SOC,
	    /* Expire watchdog after max window */
	    .window.min = 0U,
	    .window.max = WDT_MAX_WINDOW};
	wdt_channel_id = wdt_install_timeout(wdt, &wdt_config);
	if (wdt_channel_id < 0)
		LOG_ERR("Watchdog install error.");
		return wdt_channel_id;
	err = wdt_setup(wdt, WDT_OPT_PAUSE_HALTED_BY_DBG);
	if (err)
		LOG_ERR("Watchdog setup error");
		return err;
	return 0;
void app_watchdog_feed()
	wdt_feed(wdt, wdt_channel_id);
First you set it up and then you feed it on whatever interval. That WDT_MAX_WINDOW sets the timeout in milliseconds. Make sure that wdt0 in your device overlay is set to status = "okay";
    Oh and if you didn’t figure it out already make sure you set your .conf file to enable:
    # Watchdog
    CONFIG_WATCHDOG=y
    Ah yes, I set the following parameters in the .conf file:
    CONFIG_WATCHDOG=y
    CONFIG_WDT_LOG_LEVEL_DBG=y
    CONFIG_WDT_DISABLE_AT_BOOT=n
    6 days later
    Hi jaredwolff
    I’m trying to get the WDT running on our custom NRF52840 PCB, Did get the C code to compile but I need the watchdog.h file. Where can I get this or am I missing something
    THanks
    #ifndef _APP_WATCHDOG_H
    #define _APP_WATCHDOG_H
    #define WDT_MAX_WINDOW  10000U
    int app_watchdog_setup();
    void app_watchdog_feed();
    #endif
    @mvdeventer here you go!
