I initiated the init repo command previously and I have set up the project and board. When I put in the build command it prompts me to this error message…..
FAILED: build.ninja
C:\Users\gohar.zephyrtools\cmake\cmake-3.22.0-windows-x86_64\bin\cmake.exe –regenerate-during-build -SC:\Users\gohar\Desktop\Code\bootloader\mcuboot\boot\zephyr -BC:\Users\gohar\Desktop\Code\nfed\samples\button\build\mcuboot
ninja: error: rebuilding ‘build.ninja’: subcommand failed
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf C:/Users/gohar/Desktop/Code/nfed/samples/button/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build C:/Users/gohar/Desktop/Code/nfed/samples/button/build/mcuboot/zephyr/zephyr.hex C:/Users/gohar/Desktop/Code/nfed/samples/button/build/mcuboot/zephyr/zephyr.elf
cmd.exe /C “cd /D C:\Users\gohar\Desktop\Code\nfed\samples\button\build\mcuboot && C:\Users\gohar.zephyrtools\cmake\cmake-3.22.0-windows-x86_64\bin\cmake.exe –build . –”
FATAL ERROR: command exited with status 1: ‘C:\Users\gohar.zephyrtools\cmake\cmake-3.22.0-windows-x86_64\bin\cmake.EXE’ –build ‘C:\Users\gohar\Desktop\Code\nfed\samples\button\build’
Can you share the full output?
I’m assuming you set the board to circuitdojo_feather_nrf9160_ns?
You can also remove the build folder as another debug step or run a Zephyr Tools: Clean which does the same thing.
Can you also provide the version of tools you’re using? 0.1.26 is the latest as of this writing.
    jaredwolff Yes I set the board to that.
    Executing task: west build -b circuitdojo_feather_nrf9160ns
    [0/15] Performing build step for ‘spm_subimage’
    ninja: no work to do.
    [⅕] Performing build step for ‘mcuboot_subimage’
    [0/1] Re-running CMake…
    Including boilerplate (Zephyr base (cached)): C:/Users/gohar/Desktop/Code/zephyr/cmake/app/boilerplate.cmakeCMake Deprecation Warning at C:/Users/gohar/Desktop/Code/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
    The OLD behavior for policy CMP0079 will be removed from a future version
    of CMake.
    The cmake-policies(7) manual explains that the OLD behaviors of all
    policies are deprecated and that a policy should be set to OLD only under
    specific short-term circumstances. Projects should be ported to the NEW
    behavior and not rely on setting a policy to OLD.
    C:/Users/gohar/Desktop/Code/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
    C:/Users/gohar/Desktop/Code/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
    CMakeLists.txt:44 (find_package)
    – Application: C:/Users/gohar/Desktop/Code/bootloader/mcuboot/boot/zephyr
    – Zephyr version: 2.4.99 (C:/Users/gohar/Desktop/Code/zephyr)
    – Found west (found suitable version “0.13.1”, minimum required is “0.7.1”)
    – Board: circuitdojo_feather_nrf9160
    – Cache files will be written to: C:/Users/gohar/Desktop/Code/zephyr/.cache
    – Found toolchain: gnuarmemb (C:/Users/gohar/.zephyrtools/toolchain)
    – Found BOARD.dts: C:/Users/gohar/Desktop/Code/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160.dts
    – Found devicetree overlay: C:/Users/gohar/Desktop/Code/nfed/samples/button/../../shared/conf/mcuboot/circuitdojo_feather_nrf9160ns.overlay
    – Found devicetree overlay: C:/Users/gohar/Desktop/Code/bootloader/mcuboot/boot/zephyr/dts.overlay
    CMake Error at C:/Users/gohar/Desktop/Code/zephyr/cmake/dts.cmake:156 (message):
    command failed with return code: No command
    C:/Users/gohar/Desktop/Code/zephyr/cmake/app/boilerplate.cmake:533 (include)
    – Configuring incomplete, errors occurred!
    See also “C:/Users/gohar/Desktop/Code/nfed/samples/button/build/mcuboot/CMakeFiles/CMakeOutput.log”.
    See also “C:/Users/gohar/Desktop/Code/nfed/samples/button/build/mcuboot/CMakeFiles/CMakeError.log”.
    FAILED: build.ninja
    • The terminal process “C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -Command west build -b circuitdojo_feather_nrf9160ns” terminated with exit code: 1.
    • Terminal will be reused by tasks, press any key to close it.
    How did you initialize your repository? I know you mentioned you used the main branch (not supported and has been removed – the only supported branch is v1.7.x)
    I would run a Zephyr Tools: Setup and then re-init your repository with no parameter given to the branch entry.
    Make sure you’re running on the latest version of the VSCode tools. Should be 0.1.27.
