I have to say that I’m a newbie in this field, so maybe I’m doing something wrong but I cannot build using particule workbench in VS using 3.1.0 (or any more recent versions) and did all the steps from here https://github.com/circuitdojo/air-quality-wing-code
here’s my errors in VS from the debugging console:
Executing task: make -f ‘/Users/pat/.particle/toolchains/buildscripts/1.10.0/Makefile’ compile-all -s
:::: COMPILING APPLICATION & DEVICE OS
/Users/pat/.particle/toolchains/deviceOS/3.1.0/modules/argon/system-part1/makefile /Users/pat/.particle/toolchains/deviceOS/3.1.0/modules/argon/user-part/makefile
text data bss dec hex filename
444840 2550 60232 507622 7bee6 ../../../build/target/system-part1/platform-12-m/system-part1.elf
Creating /Users/pat/repo/asd2/air-quality-wing-code/target/3.1.0/argon/platform_user_ram.ld …
In file included from /Users/pat/repo/asd2/air-quality-wing-code/src/AirQualityWing.ino:9:
/Users/pat/repo/asd2/air-quality-wing-code/lib/AirQualityWing/src/AirQualityWing.h:6:21: warning: “PLATFORM_XENON” is not defined, evaluates to 0 [-Wundef]
6 | #if (PLATFORM_ID ≠ PLATFORM_XENON) && (PLATFORM_ID ≠ PLATFORM_ARGON) && (PLATFORM_ID ≠ PLATFORM_BORON)
/Users/pat/repo/asd2/air-quality-wing-code/src/AirQualityWing.ino: In function ‘void loop()’:
/Users/pat/repo/asd2/air-quality-wing-code/src/AirQualityWing.ino:80:10: error: ‘shtc3_error’ was not declared in this scope; did you mean ‘strerror’?
80 | case shtc3_error:
| strerror
/Users/pat/repo/asd2/air-quality-wing-code/src/AirQualityWing.ino:86:10: error: ‘sgp40_error’ was not declared in this scope
86 | case sgp40_error:
make[3]: *** [../build/target/user/platform-12-m/air-quality-wing-code/src/AirQualityWing.o] Error 1
make[2]: *** [user] Error 2
make[1]: *** [/Users/pat/.particle/toolchains/deviceOS/3.1.0/modules/argon/user-part/makefile] Error 2
make: *** [compile-all] Error 2
The terminal process “/bin/bash ‘-c’, ‘make -f ’/Users/pat/.particle/toolchains/buildscripts/1.10.0/Makefile’ compile-all -s’” terminated with exit code: 2.
Press any key to close the terminal.
Hey @patcardin
I downloaded and compiled locally from scratch:
 *  Executing task: make -f '/Users/jaredwolff/.particle/toolchains/buildscripts/1.10.0/Makefile' compile-user -s
Creating /Users/jaredwolff/Circuit_Dojo/aqw-particle-test/target/3.1.0/argon/platform_user_ram.ld ...
  22156     116     820   23092    5a34 /Users/jaredwolff/Circuit_Dojo/aqw-particle-test/target/3.1.0/argon/aqw-particle-test.elf
*** COMPILED SUCCESSFULLY ***
 *  Press any key to close the terminal.
Make sure that when you run git git submodule update --init --recursive it’s inside the air-quality-wing-code folder.
a month later
