Perfect. Thank you.
Board re-design
I just noticed they also have quadruplers… https://www.adafruit.com/product/4254 or https://www.adafruit.com/product/4253.
SteveD0 There you go! The more the merrier. Remember as you start using these boards you need to make sure other signals play nicely with each other. I’ve been working with a Particle Xenon + nRF9160 Feather an I had to cut the battery trace between the two. The battery chargers were not happy with each other.
K2AAE Yea exactly. If you’re nice to it, it lasts a good while. Pays for itself for big projects in no time.
Any ideas?
jaredwolff I vote for using standard connector like a Samtec FTSH-105-01-F-DV-007-K-P It has a pretty small footprint.
rbrtwtrs I have been going back and forth on this. It’s rough to add on this design. Did it with another one that’s coming out and there was enough room.
I do realize though that some folks don’t have TC cables and that was a bummer from a debugging perspective. Most folks can do most through the usage of the bootloader. I find myself using newtmgr
more often than searching for my nRF9160 DK and TC cable to program.
I noticed you have stock again, I was going to order another board after killing mine, you were OOS, good thing, I discovered I’d put the wrong Hologram SIM back in after my Verizon SIM disaster… The AT+CESQ doesn’t seem to work unless your SIM and Device are registered…
Thanks for the feedback @K2AAE. And yep back in stock. The parts you mentioned have been fun to procure
jaredwolff Finally found some CP2102! Mouser just got some, only 1K but I got a few. Quote of 52 weeks for some parts….
Yea those are tricky parts!!
