When I connect a battery to nRF9160 Feather the green (orange) LED is turned on. When I disconnect the battery the LED is blinking quite fast. Is it possible to turn this LED off? Or preferably, use it in my own programs? Or do I have to remove it with a solder iron. (Not preferred ;-) )
@kaarew you can’t control the LED. You can disable the charger, and by extension the LED, by soldering JMP2.
