Hello,
I am able to build the lpuart sample in hardware folder for nrf9160dk_nrf9160_ns but not for circuitdojo_feather_nrf9160_ns. Is possible to port to feather?
Also, I am would like to use UART1 and UART2 instead LPUART. Is the same thing, i.e. UART1 and UART2 are LPUART?
Thanks.
    vinifr What error do you get when you build for circuitdojo_feather_nrf9160_ns ?
    vinifr you need another device that is capable of using the same driver on the other side. Here’s an example of how I use it with doing HCI UART with a nRF52840:
    nRF91 Overlay:
    	chosen {
    		zephyr,bt-uart=&lpuart;
    	nrf52840_reset: gpio-reset {
    		compatible = "nordic,nrf52840-reset";
    		gpios = <&gpio0 17 GPIO_ACTIVE_LOW>;
    &uart0 {
    	current-speed = <1000000>;
    	tx-pin = <21>;
    	rx-pin = <22>;
    	/delete-property/ rts-pin;
    	/delete-property/ cts-pin;
    	/delete-property/ hw-flow-control;
    	lpuart: nrf-sw-lpuart {
    		compatible = "nordic,nrf-sw-lpuart";
    		label = "LPUART";
    		req-pin = <15>;
    		rdy-pin = <19>;
    &gpiote {
    	interrupts = <49 NRF_DEFAULT_IRQ_PRIORITY>;
    Here’s what it looks like on the other side.
    nRF52840 Overlay:
    &uart0{
    	tx-pin = <17>;
    	rx-pin = <15>;
    		label = "LPUART";
    		req-pin = <13>;
    		rdy-pin = <12>;
    	chosen {
    		zephyr,bt-c2h-uart=&lpuart;
    &gpiote {
    	interrupts = <6 NRF_DEFAULT_IRQ_PRIORITY>;
    Also some important configurations:
    CONFIG_UART_0_ASYNC=y
    CONFIG_UART_0_INTERRUPT_DRIVEN=n
    CONFIG_UART_0_NRF_HW_ASYNC=y
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=1
    CONFIG_NRF_SW_LPUART=y
    CONFIG_NRF_SW_LPUART_INT_DRIVEN=y
    The above will be slightly different depending on which UART you’re using.
    That’s totally fine too. Simply map the UART interface to the pins you want to use and make sure it’s enabled. LPUART is optional and not defined by default AFAIK.
    In file included from /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/toolchain/gcc.h:89,
                     from /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/toolchain.h:50,
                     from /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/init.h:13,
                     from /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:13,
                     from /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/drivers/uart.h:26,
                     from /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:7:
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c: In function 'lpuart_init':
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:83:41: error: '__device_dts_ord_DT_N_INST_0_nordic_nrf_sw_lpuart_BUS_ORD' undeclared (first use in this function)
       83 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
      132 | #define _DO_CONCAT(x, y) x ## y
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:83:33: note: in expansion of macro '_CONCAT'
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:209:37: note: in expansion of macro 'DEVICE_NAME_GET'
      209 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:226:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
      226 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:970:22: note: in expansion of macro 'DEVICE_DT_GET'
      970 |         data->uart = DEVICE_DT_GET(DT_INST_BUS(0));
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:83:41: note: each undeclared identifier is reported only once for each function it appears in
    In file included from /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:12:
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c: At top level:
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:326:40: error: 'DT_N_INST_0_nordic_nrf_sw_lpuart_P_req_pin' undeclared here (not in a function); did you mean 'DT_N_INST_0_nordic_nrf_uarte'?
      326 | #define DT_INST(inst, compat) UTIL_CAT(DT_N_INST, DT_DASH(inst, compat))
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:3903:29: note: in definition of macro 'DT_CAT3'
     3903 | #define DT_CAT3(a1, a2, a3) a1 ## a2 ## a3
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:3239:34: note: in expansion of macro 'DT_PROP'
     3239 | #define DT_INST_PROP(inst, prop) DT_PROP(DT_DRV_INST(inst), prop)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/sys/util_internal.h:104:26: note: in expansion of macro 'UTIL_PRIMITIVE_CAT'
      104 | #define UTIL_CAT(a, ...) UTIL_PRIMITIVE_CAT(a, __VA_ARGS__)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:326:31: note: in expansion of macro 'UTIL_CAT'
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:3048:27: note: in expansion of macro 'DT_INST'
     3048 | #define DT_DRV_INST(inst) DT_INST(inst, DT_DRV_COMPAT)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:3239:42: note: in expansion of macro 'DT_DRV_INST'
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1069:20: note: in expansion of macro 'DT_INST_PROP'
     1069 |         .req_pin = DT_INST_PROP(0, req_pin),
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:326:40: error: 'DT_N_INST_0_nordic_nrf_sw_lpuart_P_rdy_pin' undeclared here (not in a function)
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1070:20: note: in expansion of macro 'DT_INST_PROP'
     1070 |         .rdy_pin = DT_INST_PROP(0, rdy_pin)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:190:36: error: 'DT_N_NODELABEL_lpuart_PARENT_IRQ_IDX_0_VAL_priority' undeclared here (not in a function)
      190 | #define DT_NODELABEL(label) DT_CAT(DT_N_NODELABEL_, label)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/toolchain/gcc.h:78:51: note: in definition of macro 'BUILD_ASSERT'
       78 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:2218:9: note: in expansion of macro 'DT_CAT5'
     2218 |         DT_CAT5(node_id, _IRQ_IDX_, idx, _VAL_, cell)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:2245:31: note: in expansion of macro 'DT_IRQ_BY_IDX'
     2245 | #define DT_IRQ(node_id, cell) DT_IRQ_BY_IDX(node_id, 0, cell)
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1108:14: note: in expansion of macro 'DT_IRQ'
     1108 | BUILD_ASSERT(DT_IRQ(DT_PARENT(DT_NODELABEL(lpuart)), priority) ==
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:351:28: note: in expansion of macro 'UTIL_CAT'
      351 | #define DT_PARENT(node_id) UTIL_CAT(node_id, _PARENT)
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1108:21: note: in expansion of macro 'DT_PARENT'
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:190:29: note: in expansion of macro 'DT_CAT'
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1108:31: note: in expansion of macro 'DT_NODELABEL'
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:190:36: error: expression in static assertion is not an integer
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:190:36: error: 'DT_N_NODELABEL_lpuart_FULL_NAME' undeclared here (not in a function)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:857:25: note: in definition of macro 'Z_DEVICE_INIT'
      857 |                 .name = name_,                                                 \
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:940:9: note: in expansion of macro 'Z_DEVICE_BASE_DEFINE'
      940 |         Z_DEVICE_BASE_DEFINE(node_id, dev_id, name, pm, data, config, level,   \
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:178:9: note: in expansion of macro 'Z_DEVICE_DEFINE'
      178 |         Z_DEVICE_DEFINE(node_id, Z_DEVICE_DT_DEV_ID(node_id),                  \
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET'
       69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
       64 |         __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
       59 |         __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/sys/util_macro.h:157:9: note: in expansion of macro 'Z_COND_CODE_1'
      157 |         Z_COND_CODE_1(_flag, _if_1_code, _else_code)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:754:9: note: in expansion of macro 'COND_CODE_1'
      754 |         COND_CODE_1(DT_NODE_HAS_PROP(node_id, prop), \
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:144:9: note: in expansion of macro 'DT_PROP_OR'
      144 |         DT_PROP_OR(node_id, label, DT_NODE_FULL_NAME(node_id))
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/devicetree.h:514:36: note: in expansion of macro 'DT_CAT'
      514 | #define DT_NODE_FULL_NAME(node_id) DT_CAT(node_id, _FULL_NAME)
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:144:36: note: in expansion of macro 'DT_NODE_FULL_NAME'
    /home/som/projs/ams/nrf9160/ncs/zephyr/include/zephyr/device.h:179:25: note: in expansion of macro 'DEVICE_DT_NAME'
      179 |                         DEVICE_DT_NAME(node_id), init_fn, pm, data, config,    \
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1112:1: note: in expansion of macro 'DEVICE_DT_DEFINE'
     1112 | DEVICE_DT_DEFINE(DT_NODELABEL(lpuart), lpuart_init, NULL,
    /home/som/projs/ams/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1112:18: note: in expansion of macro 'DT_NODELABEL'
    FATAL ERROR: command exited with status 1: /snap/bin/cmake --build /home/som/projs/ams/nrf9160/ncs/nrf/samples/peripheral/lpuart/build
      Sorry, one more error.
      In file included from /home/vini/projs/ams_projs/nrf9160/ncs/zephyr/include/zephyr/toolchain.h:50,
                       from /home/vini/projs/ams_projs/nrf9160/ncs/zephyr/include/zephyr/init.h:13,
                       from /home/vini/projs/ams_projs/nrf9160/ncs/zephyr/include/zephyr/device.h:13,
                       from /home/vini/projs/ams_projs/nrf9160/ncs/zephyr/include/zephyr/drivers/uart.h:26,
                       from /home/vini/projs/ams_projs/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:7:
      /home/vini/projs/ams_projs/nrf9160/ncs/zephyr/include/zephyr/toolchain/gcc.h:78:36: error: static assertion failed: "UARTE and GPIOTE interrupt priority must match."
      /home/vini/projs/ams_projs/nrf9160/ncs/nrf/drivers/serial/uart_nrf_sw_lpuart.c:1108:1: note: in expansion of macro 'BUILD_ASSERT'
      Device tree code:
      &uart1 {
      	current-speed = <115200>;
      	pinctrl-0 = <&uart1_default>;
      	pinctrl-1 = <&uart1_sleep>;
      	tx-pin = <21>;
      	rx-pin = <22>;
      		label = "LPUART";
      		req-pin = <15>;
      		rdy-pin = <19>;
      You’re missing
      &gpiote {
      I didn’t omit it since it’s important 😄
