  • Air Quality Wing build for Zephyr
Ahh I can see what’s happening.
Try modifying file in .west/config to either west-ncs.yml or west-vanilla.yml and then try to init on the same folder again.
Here’s mine:
[manifest]
path = demo
file = west-ncs.yml
[zephyr]
base = zephyr
I seem to remember putting provisions for multiple manifests in the extension. What’s version do you have installed?
    Hi Jared!
    I’m now making some good progress in building AQW for Zephyr but now get some compilation errors.
    • I’ve updated .west/config to below. Thank you.
    [manifest]
    path = demo
    file = west-ncs.yml
    [zephyr]
    base = zephyr
    manifest:
      remotes:
        - name: nrfconnect
      projects:
        - name: nrf
          repo-path: sdk-nrf
          remote: nrfconnect
          revision: v2.3.0
          import: true
    • Also, I’ve updated west-vanilla.ymlto use Zephyr 3.3
    manifest:
      remotes:
        - name: zephyrproject
          url-base: https://github.com/zephyrproject-rtos
      projects:
        - name: zephyr
          repo-path: zephyr
          remote: zephyrproject
          revision: v3.3.0
    • Here is my aqw project layout in VSCode. Is aqw library at the correct place?
    quark11:aqw-test quark11$ tree -L 1
    ├── aqw
    ├── bootloader
    ├── demo
    ├── mbedtls
    ├── modules
    ├── nrf
    ├── nrfxlib
    ├── test
    ├── tools
    └── zephyr
    • After west update, all seems to be ok as far as the project settings.
      I’ve tried to build the basic example for circuitdojo_feather_nrf9160ns.
    • As the basic/src/main.c was for an earlier Zephyr,
      I updated the include files to resolve compilation errors by adding zephyr to the include paths.
    #include <zephyr/kernel.h>.
    #include <zephyr/device.h>
    #include <zephyr/drivers/sensor.h>
    #include <zephyr/devicetree.h>
    #include <aqw.h>
    #if defined(CONFIG_USB_UART_CONSOLE)
    #include <drivers/uart.h>
    #include <usb/usb_device.h>
    #endif
    • After these changes, I still get compilation errors.
      I’m getting close to a successful build with NCS 2.3.0 / Zephyr 3.2.99.
    • Are these errors because aqw library hasn’t been built?
    • How does aqw the library get built?
    • How do I fix the build errors below?
     *  Executing task: west build -b circuitdojo_feather_nrf9160_ns -p
    -- west build: making build dir /Users/quark11/Documents/aqw-test/demo/basic/build pristine
    -- Build type: debug 🚀
    -- Application: /Users/quark11/Documents/aqw-test/demo/basic
    -- Using NCS Toolchain 2.3.0 for building. (/opt/nordic/ncs/toolchains/v2.3.0/cmake)
    -- Found Python3: /opt/nordic/ncs/toolchains/v2.3.0/bin/python3 (found suitable exact version "3.9.6") found components: Interpreter
    -- Cache files will be written to: /Users/quark11/Library/Caches/zephyr
    -- Zephyr version: 3.2.99 (/Users/quark11/Documents/aqw-test/zephyr)
    -- Found west (found suitable version "0.14.0", minimum required is "0.7.1")
    -- Found host-tools: zephyr 0.15.1 (/Users/quark11/.zephyrtools/toolchain/zephyr-sdk-0.15.1)
    -- Found toolchain: zephyr 0.15.1 (/Users/quark11/.zephyrtools/toolchain/zephyr-sdk-0.15.1)
    -- Found Dtc: /opt/nordic/ncs/toolchains/v2.3.0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /Users/quark11/Documents/aqw-test/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_ns.dts
    -- Found devicetree overlay: /Users/quark11/Documents/aqw-test/demo/basic/boards/circuitdojo_feather_nrf9160_ns.overlay
    'tx-pin' is marked as deprecated in 'properties:' in /Users/quark11/Documents/aqw-test/zephyr/dts/bindings/serial/nordic,nrf-uarte.yaml for node /soc/peripheral@40000000/uart@a000.
    'rx-pin' is marked as deprecated in 'properties:' in /Users/quark11/Documents/aqw-test/zephyr/dts/bindings/serial/nordic,nrf-uarte.yaml for node /soc/peripheral@40000000/uart@a000.
    'label' is marked as deprecated in 'properties:' in /Users/quark11/Documents/aqw-test/aqw/dts/bindings/honeywell,hpma115s0.yaml for node /soc/peripheral@40000000/uart@a000/hpma115s0.
    'label' is marked as deprecated in 'properties:' in /Users/quark11/Documents/aqw-test/aqw/dts/bindings/sensirion,sgp40cd.yaml for node /soc/peripheral@40000000/i2c@9000/sgp40@59.
    'label' is marked as deprecated in 'properties:' in /Users/quark11/Documents/aqw-test/aqw/dts/bindings/sensirion,shtc3cd.yaml for node /soc/peripheral@40000000/i2c@9000/shtc3@70.
    -- Generated zephyr.dts: /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/dts.cmake
    Parsing /Users/quark11/Documents/aqw-test/demo/basic/Kconfig
    Loaded configuration '/Users/quark11/Documents/aqw-test/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_ns_defconfig'
    Merged configuration '/Users/quark11/Documents/aqw-test/demo/basic/prj.conf'
    Merged configuration '/Users/quark11/Documents/aqw-test/demo/basic/boards/circuitdojo_feather_nrf9160_ns.conf'
    Configuration saved to '/Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/.config'
    Kconfig header saved to '/Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: /Users/quark11/.zephyrtools/toolchain/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Found Python3: /opt/nordic/ncs/toolchains/v2.3.0/bin/python3 (found version "3.9.6") found components: Interpreter
    === child image mcuboot -  begin ===
    loading initial cache file /Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/child_image_preload.cmake
    -- Application: /Users/quark11/Documents/aqw-test/bootloader/mcuboot/boot/zephyr
    -- Found BOARD.dts: /Users/quark11/Documents/aqw-test/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160.dts
    -- Found devicetree overlay: /Users/quark11/Documents/aqw-test/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: /Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/zephyr/dts.cmake
    warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
    Parsing /Users/quark11/Documents/aqw-test/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration '/Users/quark11/Documents/aqw-test/zephyr/boards/arm/circuitdojo_feather_nrf9160/circuitdojo_feather_nrf9160_defconfig'
    Merged configuration '/Users/quark11/Documents/aqw-test/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration '/Users/quark11/Documents/aqw-test/bootloader/mcuboot/boot/zephyr/boards/circuitdojo_feather_nrf9160.conf'
    Merged configuration '/Users/quark11/Documents/aqw-test/nrf/modules/mcuboot/tfm.conf'
    Merged configuration '/Users/quark11/Documents/aqw-test/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration '/Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/zephyr/.config'
    Kconfig header saved to '/Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: /Users/quark11/Documents/aqw-test/bootloader/mcuboot/root-ec-p256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/quark11/Documents/aqw-test/demo/basic/build/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at /Users/quark11/Documents/aqw-test/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
              --- be used for production.                           ---
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done
    -- Generating done
    [2/268] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (/Users/quark11/Documents/aqw-test/zephyr), build: v3.2.99-ncs2
    [23/268] Performing build step for 'mcuboot_subimage'
    [1/203] Preparing syscall dependency handling
    [2/203] Generating include/generated/version.h
    [193/203] Linking C executable zephyr/zephyr_pre0.elf
    [197/203] Linking C executable zephyr/zephyr_pre1.elf
    [203/203] Linking C executable zephyr/zephyr.elf
               FLASH:       44204 B        48 KB     89.93%
                 RAM:       24304 B        32 KB     74.17%
            IDT_LIST:          0 GB         2 KB      0.00%
    [55/268] Preparing syscall dependency handling
    [63/268] Generating ../../tfm/CMakeCache.txt
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/quark11/Documents/aqw-test/demo/basic/build/tfm
    [69/268] Performing build step for 'tfm'
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [172/172] Linking C static library secure_fw/libtfm_s_veneers.a
    [73/268] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [115/268] Building C object CMakeFiles/app.dir/src/main.c.obj
    FAILED: CMakeFiles/app.dir/src/main.c.obj
    ccache /Users/quark11/.zephyrtools/toolchain/zephyr-sdk-0.15.1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DTFM_PSA_API -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -I/Users/quark11/Documents/aqw-test/zephyr/include -I/Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated -I/Users/quark11/Documents/aqw-test/zephyr/soc/arm/nordic_nrf/nrf91 -I/Users/quark11/Documents/aqw-test/zephyr/lib/libc/newlib/include -I/Users/quark11/Documents/aqw-test/zephyr/soc/arm/nordic_nrf/common/. -I/Users/quark11/Documents/aqw-test/nrf/include -I/Users/quark11/Documents/aqw-test/nrf/include/tfm -I/Users/quark11/Documents/aqw-test/nrf/tests/include -I/Users/quark11/Documents/aqw-test/aqw/drivers/sensirion-common -I/Users/quark11/Documents/aqw-test/aqw/include -I/Users/quark11/Documents/aqw-test/aqw/drivers -I/Users/quark11/Documents/aqw-test/aqw/ext/embedded-sgp/sgp40_voc_index -I/Users/quark11/Documents/aqw-test/modules/lib/golioth/include -I/Users/quark11/Documents/aqw-test/demo/basic/build/tfm/generated/interface/include -I/Users/quark11/Documents/aqw-test/modules/hal/cmsis/CMSIS/Core/Include -I/Users/quark11/Documents/aqw-test/modules/hal/nordic/nrfx -I/Users/quark11/Documents/aqw-test/modules/hal/nordic/nrfx/drivers/include -I/Users/quark11/Documents/aqw-test/modules/hal/nordic/nrfx/mdk -I/Users/quark11/Documents/aqw-test/zephyr/modules/hal_nordic/nrfx/. -I/Users/quark11/Documents/aqw-test/nrfxlib/nrf_modem/include -I/Users/quark11/Documents/aqw-test/demo/basic/build/tfm/install/interface/include -I/Users/quark11/Documents/aqw-test/demo/basic/build/modules/nrfxlib/nrfxlib/nrf_security/src/include/generated -I/Users/quark11/Documents/aqw-test/nrfxlib/nrf_security/include -I/Users/quark11/Documents/aqw-test/nrfxlib/nrf_security/include/mbedtls -I/Users/quark11/Documents/aqw-test/modules/crypto/mbedtls/include -I/Users/quark11/Documents/aqw-test/modules/crypto/mbedtls/include/mbedtls -I/Users/quark11/Documents/aqw-test/modules/crypto/mbedtls/include/psa -I/Users/quark11/Documents/aqw-test/modules/crypto/mbedtls/library -I/Users/quark11/Documents/aqw-test/nrfxlib/crypto/nrf_oberon/include/mbedtls -I/Users/quark11/Documents/aqw-test/nrfxlib/crypto/nrf_oberon/include -fno-strict-aliasing -Os -imacros /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/Users/quark11/.zephyrtools/toolchain/zephyr-sdk-0.15.1/arm-zephyr-eabi/arm-zephyr-eabi -imacros /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/Users/quark11/Documents/aqw-test/demo/basic=CMAKE_SOURCE_DIR -fmacro-prefix-map=/Users/quark11/Documents/aqw-test/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/Users/quark11/Documents/aqw-test=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles/app.dir/src/main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c /Users/quark11/Documents/aqw-test/demo/basic/src/main.c
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:37:10: error: 'struct aqw_sensor' has no member named 'dev_name'
       37 |         .dev_name = CONFIG_SHTC3_DEV_NAME,
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:37:13: warning: Macro is deprecated
    In file included from /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:19,
                     from /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/arch/arm/aarch32/arch.h:20,
                     from /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/arch/cpu.h:19,
                     from /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/kernel_includes.h:33,
                     from /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/kernel.h:17,
                     from /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:6:
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:11736:72: warning: initialization of 'unsigned int' from 'char *' makes integer from pointer without a cast [-Wint-conversion]
    11736 | #define DT_N_S_soc_S_peripheral_40000000_S_i2c_9000_S_shtc3_70_P_label "SHTC3"
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:3903:29: note: in expansion of macro 'DT_N_S_soc_S_peripheral_40000000_S_i2c_9000_S_shtc3_70_P_label'
     3903 | #define DT_CAT3(a1, a2, a3) a1 ## a2 ## a3
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:607:32: note: in expansion of macro 'DT_CAT3'
      607 | #define DT_PROP(node_id, prop) DT_CAT3(node_id, _P_, prop)
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:766:27: note: in expansion of macro 'DT_PROP'
      766 | #define DT_LABEL(node_id) DT_PROP(node_id, label) __DEPRECATED_MACRO
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:22:31: note: in expansion of macro 'DT_LABEL'
       22 | #define CONFIG_SHTC3_DEV_NAME DT_LABEL(SHTC3)
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in expansion of macro 'DT_N_INST_0_sensirion_shtc3cd'
      105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/sys/util_internal.h:104:26: note: in expansion of macro 'UTIL_PRIMITIVE_CAT'
      104 | #define UTIL_CAT(a, ...) UTIL_PRIMITIVE_CAT(a, __VA_ARGS__)
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:326:31: note: in expansion of macro 'UTIL_CAT'
      326 | #define DT_INST(inst, compat) UTIL_CAT(DT_N_INST, DT_DASH(inst, compat))
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:21:15: note: in expansion of macro 'DT_INST'
       21 | #define SHTC3 DT_INST(0, sensirion_shtc3cd)
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:22:40: note: in expansion of macro 'SHTC3'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:37:21: note: in expansion of macro 'CONFIG_SHTC3_DEV_NAME'
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:11736:72: note: (near initialization for 'temperature_sensor.interval')
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:45:10: error: 'struct aqw_sensor' has no member named 'dev_name'
       45 |         .dev_name = CONFIG_SHTC3_DEV_NAME,
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:45:13: warning: Macro is deprecated
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:45:21: note: in expansion of macro 'CONFIG_SHTC3_DEV_NAME'
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:11736:72: note: (near initialization for 'humidity_sensor.interval')
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:53:10: error: 'struct aqw_sensor' has no member named 'dev_name'
       53 |         .dev_name = CONFIG_SGP40_DEV_NAME,
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:53:13: warning: Macro is deprecated
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:11620:72: warning: initialization of 'unsigned int' from 'char *' makes integer from pointer without a cast [-Wint-conversion]
    11620 | #define DT_N_S_soc_S_peripheral_40000000_S_i2c_9000_S_sgp40_59_P_label "SGP40"
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:3903:29: note: in expansion of macro 'DT_N_S_soc_S_peripheral_40000000_S_i2c_9000_S_sgp40_59_P_label'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:25:31: note: in expansion of macro 'DT_LABEL'
       25 | #define CONFIG_SGP40_DEV_NAME DT_LABEL(SGP40)
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in expansion of macro 'DT_N_INST_0_sensirion_sgp40cd'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:24:15: note: in expansion of macro 'DT_INST'
       24 | #define SGP40 DT_INST(0, sensirion_sgp40cd)
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:25:40: note: in expansion of macro 'SGP40'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:53:21: note: in expansion of macro 'CONFIG_SGP40_DEV_NAME'
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:11620:72: note: (near initialization for 'voc_sensor.interval')
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:61:10: error: 'struct aqw_sensor' has no member named 'dev_name'
       61 |         .dev_name = CONFIG_HPMA115S0_DEV_NAME,
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:61:13: warning: Macro is deprecated
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:12437:74: warning: initialization of 'unsigned int' from 'char *' makes integer from pointer without a cast [-Wint-conversion]
    12437 | #define DT_N_S_soc_S_peripheral_40000000_S_uart_a000_S_hpma115s0_P_label "HPMA115S0"
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/devicetree.h:3903:29: note: in expansion of macro 'DT_N_S_soc_S_peripheral_40000000_S_uart_a000_S_hpma115s0_P_label'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:28:35: note: in expansion of macro 'DT_LABEL'
       28 | #define CONFIG_HPMA115S0_DEV_NAME DT_LABEL(HPMA115S0)
    /Users/quark11/Documents/aqw-test/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in expansion of macro 'DT_N_INST_0_honeywell_hpma115s0'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:27:19: note: in expansion of macro 'DT_INST'
       27 | #define HPMA115S0 DT_INST(0, honeywell_hpma115s0)
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:28:44: note: in expansion of macro 'HPMA115S0'
    /Users/quark11/Documents/aqw-test/demo/basic/src/main.c:61:21: note: in expansion of macro 'CONFIG_HPMA115S0_DEV_NAME'
    /Users/quark11/Documents/aqw-test/demo/basic/build/zephyr/include/generated/devicetree_generated.h:12437:74: note: (near initialization for 'hpma_sensor.interval')
    [120/268] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    FATAL ERROR: command exited with status 1: /Users/quark11/.zephyrtools/cmake/cmake-3.22.0-macos-universal/CMake.app/Contents/bin/cmake --build /Users/quark11/Documents/aqw-test/demo/basic/build
     *  The terminal process "/usr/local/bin/bash '-c', 'west build -b circuitdojo_feather_nrf9160_ns -p'" terminated with exit code: 1.
     *  Terminal will be reused by tasks, press any key to close it.
    I’m pretty keen to get build AQW for Zephyr successfully so that I can proceed to order the aqw / sensor hardware. Appreciate your help!
      zpm1066 thanks for the info!
      I actually had the upgrade work in another branch that I forgot to push to main. If you run Zephyr Tools: Update Dependencies that should get you to the latest!
      Also, you’ll need to do a git pull in the demo repo before you do that update.
        Success! A git pull in the demo repo, followed by a Zephyr Tools: Update Dependenciesdid the trick. Thank you.
        I’m able to build the AQW examples for particle_xenon and circuitdojo_feather_nrf9160_ns. I’ve also flashed the examples onto particle_xenon using a Segger Edu Mini jlink. For the basic example, I’m able to see the console debug output and for the ble example, I was able to connect via bluetooth. All good stuff!
        I was also able to switch between west-ncs.yml (NCS 2.3) and west-vanilla.yml (Zephyr 3.3.99) using
        west config manifest.file west-ncs.yml (west config manifest.file west-vanilla.yml)
        west update
        Question - How do the AQW examples know where to pull in the AQW library?
        How does the AQW library gets built?
        Appreciate if you direct me to appropriate area of build / code. Thank you!
        To assist anyone else who may be having issues building AQW fro Zephyr, here’s additional steps that may help you.
        Initially, I setup AQW for Zephyr with assistance from Jared. Yesterday, I repeated, the AQW build for Zephyr on macOS Catalina, and was able to build the AQW examples successfully.
        jaredwolff The nrf9160feather setup works cleanly without any additional changes. It would be good to have the same for AQW at some stage.
        1. SDK Setup - download Circuit Dojo Zephyr SDK Tools and install
        2. Run Setup - Open command window in VSCode and type Zephyr Tools: Setup
        3. Create an empty folder for AQW repo, for example "aqw-demo"
        4. Initialize the repo using the Zephyr Tools:Init Repo command
        5. Make sure you use https://github.com/circuitdojo/air-quality-wing-zephyr-demo.git as the URL
        6. If you get a manifest-tmp error (as currently 04/15/23), move manifest-tmp to aqw-demo folder and rename io demo
        7. In aqw-demo/.west, create config file
        	[manifest]
        	path = demo
        	file = west-ncs.yml
        	[zephyr]
        	base = zephyr
        8. There are two yml files in aqw-demo/demo, west-ncs.yml for Nordic NCS, and west-vanilla.yml for generic Zephyr
           west-ncs.yml - Change revision to v2.3.0 to the currently latest Nordic NCS
        west-vanilla.yml - Change revision to the latest Zephyr if desired, currently v3.3.0
        9. In VSCode Explorer window, select the demo folder & right-click and select "Open in integrated Terminal"
        From within the demo repo terminal window, run "git pull" to get the latest aqw repo updates 10. In VSCode Explorer window, select the .west folder & right-click and select "Open in integrated Terminal" From within the .west terminal window, run "west update" to update the zephyr repo.
        11. Run (macOS: Shift + Cmd + P) Zephyr Tools:Change Board - Select particle_xenon Current supported board targets include:
        particle_xenon circuitdojo_feather_nrf9160_ns nrf52840dk_nrf52840 12. Run Zephyr Tools:Change Project - Select project, for example "basic" 13. Run Zephyr Tools:Init Repo, navigate to the aqw-demo folder You may get prompted to update "pip", run: pip install --upgrade pip from a .west terminal window
        14. Run Zephyr Tools:Build Once the build completes you should get a "Build complete!" popup along with success messages in the the terminal. 15. Code may be flashed using a link probe, for example, Segger Edu Mini (preferable for debugging & Segger RTT) Alternatively, place the device into bootloader mode, then load using the Zephyr Tools: Load via Bootloader task.
        Switching repo from NCS (west-ncs.yml) to vanilla Zephyr (west-vanilla.yml) 1. From a VSCode .west terminal window, run the following comamnds to switch from NCS to vanilla zephyr. west config manifest.file west-vanilla.yml west update After executing the above commands, aqw-demo/.west/config will get modified to use "file = west-vanilla.yml".
        The zephyr repo can be switch back to using NCS by running the following.
        west config manifest.file west-ncs.yml west update
          One more thing …
          How do I attach an image to a post from a macOS. I tried using both Safari and Chrome, no luck.
          When I click the “Add an image” icon, I do not get adoption to browse and select an image to upload.
          What am I doing wrong? Thanks.
            zpm1066 When I click the “Add an image” icon, I do not get adoption to browse and select an image to upload.
            I usually drag into the chat box. Not sure why your dialogue is not opening. I use the forum both on Firefox and Safari.
            zpm1066 It would be good to have the same for AQW at some stage.
            Thanks for the suggestions zpm1066. I’ll add it to my list!
              Which version of macOS and Safari are you using? I’m using macOS Big Sur and Catalina.
              I’ve tried dragging an image into the chat box, all I get is the full path to the file displayed.
              /Users/quasar1015/Desktop/test.png
              or if I click on the “Add an image” icon, I get the cursor between the brackets [].
              ![](https://)
              Weird!
              The latest ones as far as I can tell. Make sure you have JS enabled.
                I’ve installed a fresh instance of the latest Firefox but get the same issue. So far, I’ve tried Safari, Chrome, and Firefox on macOS (Monterey, Big Sur, Catalina) and Windows 10 and 11 from three several Macs & Windows machines.
                JS is enabled and pop-ups are allowed. I don’t have issues uploading images on community forums at particle.io, platformio.org and other forums.
                Just weird and little frustrating!
                I didn’t see anything in the forum settings that I needed to change.
                Is there anyone I can reach out to who run your community forum? Thanks.
                It’s not an extension but a jpg file that I’m trying to upload.
                In the browsers, e.g. Safari 16.4.1 (latest for BigSur), I have JS enabled and pop-ups allowed. I don’t have any blockers.
                Is there any other Safari preference I need to change? Thanks!
