A while back in the AQW docs, I noticed that there was a photo of an antenna (Bluetooth) being used with your enclosure that probably had a particle_xenon board. I have a BT antenna for my AQW enclosure that I plan to use with AQW.
In reviewing Zephyr code, on power-up, board_particle_xenon_init() forces PCB antenna selection. What is the best way to select the external antenna? Any code you can share? Thanks.
Also, Are there any precautions I need to take whilst hooking up an antenna, e.g. power down AQW?
