Yes, that’s the only way to send real time data and retrieve it.
    From the link you shared above and ethernet_hub_ble code unchanged, I should be able use Golioth's WebSocket API to graph the LightDB State data.
    Steps:
    1. Install the Golioth’s WebSocket API in the Grafana Cloud instance
    2. Create a WebSocket API data source
    3. Fill in the WebSocket API info:
      Host: wss://api.golioth.io/v1/projects/{Project ID}, add Custom Headers
      Header: X-API-Key and the value, then Save & test
      Grafana displays that the “Data source is working”.
    4. Create a dashboard with the following.
      Set Data source to WebSocket API
      Add Path and Fields for LightDB State and transform the JSON result into something that the dashboard can display, for example
      Path: /devices/{Device Id}
      Field $..env.hum
      Field $..env.temp
    LightDB State
    {1 item
         "env":{4 items
           "hum":30
           "pm25":2
           "temp":26
           "voc":52
    I tried creating a dashboard but got error Some queries returned an error: Query A - undefined.
    I don’t see anything wrong with Data source configuration but there may be some other configuration issue.
    I’ll open a ticket with Grafana Support.
      6 days later
      I’ve confirmed that the data source is returning data correctly using websocat from a macOS terminal session.
      Below, I’ve replaced actual “Device Id” and “APIkey” by “mydeviceid” and “myapikey”
      $ websocat wss://api.golioth.io/v1/ws/projects/aqw1066/devices/mydeviceid/data?x-api-key=myapikey
      {"result":{"data":{"env":{"hum":33,"pm25":0,"temp":29,"voc":157}}}}
      {"result":{"data":{"env":{"hum":32,"pm25":0,"temp":29,"voc":153}}}}
      Next step, check why Grafana isn’t getting the data.
      zpm1066
      I’ve also ran curl against the device’s JSON endpoint to confirm that JSON data source returns the expected sensor data. Below, I’ve replaced the actual API key by myapikey.
      $ curl -X 'GET' \
      'https://api.golioth.io/v1/projects/aqw1066/devices/643c620df272169b4557ee61/data/env' \
      -H 'accept: application/json' \
      -H 'x-api-key: myapikey' \
      -H 'Authorization: myapikey'
      {"data":{"hum":20,"pm25":0,"temp":41,"voc":265}
      5 days later
      @zpm1066 playing around with this now. I’m not even getting stream data from the wss endpoint. Stay tuned on that
        Hello Jared,
        It looks like the WebSocket API plugin through Grafana has a few issues. Grafana support informed me that I need to approach Goliath support as it’s a third party plugin. I had the same issue with JSON API with Grafana.
        A resource in Grafana has kindly offered to assist. So, hopefully will get a resolution soon.
        Sound good. I know they worked on it a while back so it’s likely it could be broken especially if there’s not a ton of people using it.
          Success!! I had call with Golioth and was recommended to use the JSON APIfor both LightDb State and LightDB Stream, as the sensors publish data at relatively slow interval of per minute.
          The resolution turned out to be a minor change in the Grafana Dashboard Path, plus an addition of a query in the Body of the Dashboard configuration.
          I used the version of JSON API plugin that is available in Grafana Cloud, the same one that I tried using earlier.
          Golioth weren’t sure why the WebSocket API didn’t work and will get back to me.
          Later I’ll setup separate charts for each of the sensors, as you had in your JSON.
          What’s the best to generate what you had in the Air Quality Wing-1633657750477.json? Thanks.
          Data source - JSON API
          Dashboard Configuration
          Path
          POST
          /devices/mydevicei/stream
          Fields
          $..time
          $..env.hum
          $..env.voc
          $..env.temp
          $..env.p25
          Body
          	"start" : "${__from:date}",
                  "end" : "${__to:date}",
          	"perPage" : 99999,
          	"query": {
          		"fields" : [
          			{ "path": "time" },
          			{ "path": "deviceId"},
          			{ "path": "*"}
          		"timeBucket" : "5s"
          @jaredwolff
          btw - Currently, I’m running with Segger RTT output enabled and noticed that if I close the J-Link RTT viewer the sensor data stops going to Golioth.
          In your ethernet_hub_ble code, you have Segger RTT disabled. I’ll check what’s going on.
          Thanks. There seems to be an issue with the Golioth WebSocket plugin for Grafana Cloud. Another user had the same issue as me. Hopefully we’ll see someone from on Golioth Forum can assist.
