tcpipchip Hi, with this module, can i reach to LTE FDD bands 1, 2, 3, 4, 5, 7, 8, 12, 20, 28, 66 LTE TDD bands 38, 40, 41 2G bands Q Data rate Cat 1 ? Thanks
jaredwolff This page has everything you need to know about which bands the nRF91 covers: https://www.nordicsemi.com/Products/Low-power-cellular-IoT/nRF9160-Certifications Only Cat M1 and NB bands.
tcpipchip This means that will NOT work with 2G and 3G, right ? And the flash is necessary ? i dont want to store data…all will be transmited to cloud Is that coming with Footprint wrote ANATEL CERTIFIED ? (BRAZIL) How can i order a unit ?
jaredwolff This means that will NOT work with 2G and 3G, right ? Correct And the flash is necessary ? i dont want to store data…all will be transmited to cloud I’m not sure what you mean. You can use the device however you’d like. You need to program it using the C programming language to do so though. Is that coming with Footprint wrote ANATEL CERTIFIED ? (BRAZIL) The link above should indicate what certifications are supported by the module. How can i order a unit ? If you’re talking about the nRF9160 Feather, here: https://www.jaredwolff.com/store/ or on Digikey https://www.digikey.com/en/products/detail/circuit-dojo/PASSY-NRF9160-FEATHER/13668137
jaredwolff Also, I would check to make sure the provider you want to use supports CAT M1 and/or NB IoT tcpipchip
