Hi, with this module, can i reach to
LTE FDD bands 1, 2, 3, 4, 5, 7, 8, 12, 20, 28, 66
LTE TDD bands 38, 40, 41
2G bands Q
Data rate Cat 1
Thanks
This means that will NOT work with 2G and 3G, right ?
And the flash is necessary ? i dont want to store data…all will be transmited to cloud
Is that coming with Footprint wrote ANATEL CERTIFIED ? (BRAZIL)
How can i order a unit ?
    Correct
    I’m not sure what you mean. You can use the device however you’d like. You need to program it using the C programming language to do so though.
    The link above should indicate what certifications are supported by the module.
    If you’re talking about the nRF9160 Feather, here: https://www.jaredwolff.com/store/ or on Digikey https://www.digikey.com/en/products/detail/circuit-dojo/PASSY-NRF9160-FEATHER/13668137
    Also, I would check to make sure the provider you want to use supports CAT M1 and/or NB IoT tcpipchip
