Hello! I was getting ready to buy an AQW to use with a Particle board like your original documentation outlined, then I came here and read that people are apparently having issues using AQW plus Particle. Does your original documentation (i.e here: https://www.jaredwolff.com/how-to-use-particle-squared-air-quality-sensor/ and https://docs.circuitdojo.com/air-quality-wing/arduino-examples.html) still work? If so, which particle boards is AQW currently compatible with? I’d like to follow the original particle tutorial above, if AQW still works with particle per the tutorial.
