Hello,
I’m looking for the right hardware combination that will allow me to view PLC sensor data from industrial production equipment through my cloud platform. Or some links to some existing projects that I can use and build upon.
I have two versions of PLC - some communicate through Modbus RTU and some through the ethernet port. Additionally, the hardware will need to pick up two additional temperature sensors and a current transformer that are not connected to the PLC and then send that data to the cloud platform as well. The only space that’s available in the panel is 7in x 5in x 4in.
I’ve already found the feather board and a serial driver, but what is the best board to tie everything together? What would be the best IP65 enclosure to use? Any help will be greatly appreciated.
Thank you,
DS
