Hi, my name is Vincent.
I ended up here while hunting for documentation, solution and support.
I ended up watching https://www.youtube.com/watch?v=YgMmxa6gRqA . I was impressed by the communication skills and Zephyr’s overall knowledge!
I am actually very new to the Zephyr World and the Nordic development environment.
I have a nRF7002DK board, that I am trying to connect to Azure IoT Hub and provision a device with DPS.
I am able to build the Azure IoT Hub example on its own. But I struggle to integrate it with the rest of my code.
I am using the example from this specific version: v2.5.0\nrf\samples\net\azure_iot_hub
When I add it to my more extensive project, I end up with a flash size error.
I spent more than 3 days trying to fix the issues. But I believe, I need help now to unblock me.
Thanks in advance to anyone who is going to help me get unblocked and show me the path forward in my understanding.
Here’s the actual build error.
[489/616] Building C object modules/nrf/drivers/wifi/nrf700x/CMakeFiles/..__nrf__drivers__wifi__nrf700x.dir/osal/utils/src/queue.c.obj
[489/616] Performing build step for 'mcuboot_subimage'
[1/273] Generating ../../zephyr/include/generated/ncs_version.h
[273/273] Linking C executable zephyr\zephyr.elf
FLASH: 60780 B 64 KB 92.74%
RAM: 289580 B 440 KB 64.27%
IDT_LIST: 0 GB 2 KB 0.00%
[498/616] Generating ../../zephyr/net_core_app_update.bin
image.py: sign the payload
[500/616] Generating ../../zephyr/net_core_app_signed.hex
[518/616] Generating ../../zephyr/net_core_app_test_update.hex
[599/616] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Nordic\milo_fw\nRF5340_app_core\build\zephyr && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe -E true""
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 19476 bytes
collect2.exe: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\Nordic\milo_fw\nRF5340_app_core\build'
* The terminal process terminated with exit code: 1.
