Hi guys 🙂 For some weird reason, the onboard i2c devices fail to respond when I add my external i2c sensor. I’ve tested a couple of things, and it seems to be related to the SDA and SCL lines, as if I remove those, the onboard devices work (accel and pcf85063a).
I’m bascially seeing errors like the below in my log:
[00:00:01.319,549] <err> i2c_nrfx_twim: Error 0x0BAE0001 occurred for message 0
[00:00:01.327,667] <err> pcf85063a: Unable to stop RTC. (err -5)
My i2c conf is:
&i2c1 {
zephyr,concat-buf-size = <256>;
clock-frequency = < I2C_BITRATE_STANDARD >;
accel0: lis2dh@18 {
compatible = "st,lis2dh";
reg = <0x18>;
irq-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>, <&gpio0 30 GPIO_ACTIVE_HIGH>;
disconnect-sdo-sa0-pull-up;
pcf85063a: pcf85063a@51 {
compatible = "nxp,pcf85063a";
reg = <0x51>;
Any pointers on where go start debugging this?
