Hello everyone,
incredible work done with this board!
I have purchased nrf9160 feather + nRF5340-DK + TagConnect to play around with this beautiful board and test a tracker application.
I have tried to use CircuitDojo plugin for VSCode, but I’m having trouble with debugging and I have limited time.
I would like to try the nRF Connect extension for VSCode, which has debug feature integrated.
Will the board work? I don’t need bootloader, security etc, just need to test some accelerometer, GPS and LTE feature, and active sleep, but I need debugging for easy of use.
My idea would be to build CircuitDojo example under nRF Connect VSCode environment
Is it possible? Is there something that has to be done to make it work?
Thank you for the help!!
Hi @PaoloZigoni
Nordic’s extension should work especially if you have a programmer. It’s not supported here though. You should contact Nordic directly if you have any issues.
