Hey All,
I am using Hologram SIMs. They work well, but data speeds are okay for only sending small files. I also have need to send much more data. Are there other SIMs that would provide me with faster upload speeds?
Thanks.
Do you use LTE-M? Or NB-IoT? Both is not really intended for “much more data” and “faster speeds”. I consider LTE-M somehow as “medium performant”, and NB-IoT as “low performant”. These technologies are introduced for energy and cost sensitive applications. If you need “more data and speed”, you will need to use an other cellular standard (other modem), which then comes also with higher energy consumption and costs.
Well said @AchimKraus. I’ll add that you should look into Cat1 (or higher) devices if you are indeed transferring large files frequently. (Large IMO is anything > 10kB)
