Zephyr Tools: Setup this runs successfully
Zephyr Tools: Init this comes up with the following error.
=== updating zscilib (modules/lib/zscilib):
HEAD is now at 0035be5 Merge pull request #45 from uLipe/feature/qrd_no_recursion
* Executing task: pip install -r zephyr/scripts/requirements.txt
[notice] A new release of pip is available: 24.2 -> 24.3.1
[notice] To update, run: python3.12 -m pip install --upgrade pip
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try brew install
xyz, where xyz is the package you are trying to
install.
If you wish to install a Python library that isn't in Homebrew,
use a virtual environment:
python3 -m venv path/to/venv
source path/to/venv/bin/activate
python3 -m pip install xyz
If you wish to install a Python application that isn't in Homebrew,
it may be easiest to use 'pipx install xyz', which will manage a
virtual environment for you. You can install pipx with
brew install pipx
You may restore the old behavior of pip by passing
the '--break-system-packages' flag to pip, or by adding
'break-system-packages = true' to your pip.conf file. The latter
will permanently disable this error.
If you disable this error, we STRONGLY recommend that you additionally
pass the '--user' flag to pip, or set 'user = true' in your pip.conf
file. Failure to do this can result in a broken Homebrew installation.
Read more about this behavior here: <https://peps.python.org/pep-0668/>
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
* The terminal process "/bin/zsh '-l', '-c', 'pip install -r zephyr/scripts/requirements.txt'" terminated with exit code: 1.
env | grep PATH
PATH=/usr/local/opt/python/libexec/bin:/usr/local/opt/python/libexec/bin:/Library/Frameworks/Python.framework/Versions/3.11/bin:/usr/local/bin:/usr/local/sbin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/adamcatle/Library/Python/3.11/bin:/Users/adamcatle/.zephyrtools/env/bin:/Users/adamcatle/.zephyrtools/env/Scripts:/Users/adamcatle/.zephyrtools/toolchain/zephyr-sdk-0.16.4/arm-zephyr-eabi/bin/:/Users/adamcatle/.zephyrtools/cmake/cmake-3.22.0-macos-universal/CMake.app/Contents/bin/:/Users/adamcatle/.zephyrtools/ninja/:/Users/adamcatle/.zephyrtools/newtmgr/:/Users/adamcatle/.zephyrtools/zephyr-tools/:/usr/local/opt/python/libexec/bin:/Library/Frameworks/Python.framework/Versions/3.11/bin:/Users/adamcatle/.local/bin:/Users/adamcatle/.local/bin
INFOPATH=/usr/local/share/info:/usr/local/share/info:
