I am using AWS and MQTT. I have not been able to figure out why i keep getting stale, repeat MQTT messages. for instance, I changed my device shadow on AWS, and I get the new MQTT message, version 513, which is correct, but then I get message 510.
Question: Is there something in my handling of the MQTT message that I need to do to say I received the MQTT message so it doesn’t get sent again?
This is the order I receive them. You can see that timestamps for earlier versions are older.
Received: {“version”:515,“timestamp”:1730299139,“state”:{“whitelist”:[]},“metadata”:{“whitelist”:[]}}
topic: $aws/things/RichGateway/shadow/name/G2000-022512/update/delta
Received: {“version”:509,“timestamp”:1730298928,“state”:{“whitelist”:[]},“metadata”:{“whitelist”:[]}}
Received: {“version”:512,“timestamp”:1730299045,“state”:{“whitelist”:[“PS4550-04143”]},“metadata”:{“whitelist”:[{“timestamp”:1730299045}]}}
Received: {“version”:514,“timestamp”:1730299097,“state”:{“whitelist”:[“PS4550-04143”]},“metadata”:{“whitelist”:[{“timestamp”:1730299097}]}}
Received: {“version”:513,“timestamp”:1730299069,“state”:{“whitelist”:[]},“metadata”:{“whitelist”:[]}}
Received: {“version”:510,“timestamp”:1730298953,“state”:{“whitelist”:[“PS4550-04143”]},“metadata”:{“whitelist”:[{“timestamp”:1730298953}]}}
Get Whitelist, Code, …
Hi @RichSurprenant
If you’re using the AWS specific client, it should ack messages that require one. Can you confirm you’re using the AWS specific MQTT implementation?
I AM using the AWS specific MQTT implementation. I don’t see the ACK. Do you have any pointers to look to LOG it?
    It’s in the on_publish function in mqtt_helper.c (See send_ack) There’s no logging there so you may not see anything. It only sends an ACK if QOS==1
    MQTT_HELPER_STATIC void on_publish(const struct mqtt_evt *mqtt_evt)
    	int err;
    	const struct mqtt_publish_param *p = &mqtt_evt->param.publish;
    	struct mqtt_helper_buf topic = {
    		.ptr = (char *)p->message.topic.topic.utf8,
    		.size = p->message.topic.topic.size,
    	struct mqtt_helper_buf payload = {
    		.ptr = payload_buf,
    	err = publish_get_payload(&mqtt_client, p->message.payload.len);
    	if (err) {
    		LOG_ERR("publish_get_payload, error: %d", err);
    		if (current_cfg.cb.on_error) {
    			current_cfg.cb.on_error(MQTT_HELPER_ERROR_MSG_SIZE);
    		return;
    	if (p->message.topic.qos == MQTT_QOS_1_AT_LEAST_ONCE) {
    		send_ack(&mqtt_client, p->message_id);
    	payload.size = p->message.payload.len;
    	if (current_cfg.cb.on_publish) {
    		current_cfg.cb.on_publish(topic, payload);
    Jared, thank you so much. This problem has been plaguing me for months. Your response prompted me to look at the aws_iot implemenation, which I branch off of so long ago. I discovered that I was missing this ack:
    	case MQTT_EVT_PUBLISH: {
    		LOG_DBG("MQTT_EVT_PUBLISH: id = %d len = %d ",
    			p->message_id,
    		err = publish_get_payload(c, p->message.payload.len);
    		if (err) {
    			break;
    			const struct mqtt_puback_param ack = {
    				.message_id = p->message_id
    			mqtt_publish_qos1_ack(c, &ack);
    When i added the ack, it fixed the problem. Again, thanks… :-)
