Anyone successfully update the feather to the 1.3.7 firmware? When I attempt to do so, I get the following error:
% python3 update_modem.py ~/Downloads/mfw_nrf9160_1.3.7.zip /dev/tty.usbserial-510 1000000
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Dll directory is /Users/robert/.virtualenvs/zephyr/lib/python3.11/site-packages/pynrfjprog/lib_x64.
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Find and connect to dfu dll
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Using DFU dll at /Users/robert/.virtualenvs/zephyr/lib/python3.11/site-packages/pynrfjprog/lib_x64/libnrfdfu.dylib.
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Load library at /Users/robert/.virtualenvs/zephyr/lib/python3.11/site-packages/pynrfjprog/lib_x64/libnrfdfu.dylib.
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Library loaded, loading member functions.
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Member functions succesfully loaded.
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Initialize new probe.
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Successfully opened port: /dev/tty.usbserial-510@1000000,flow_control:none,parity:none.
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Error caught in parse_stat_response: Key not found: 'rc'
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {
    "duration": 569,
    "error_code": "Ok",
    "operation": "open_uart",
    "outcome": "success",
    "progress_percentage": 100
[HighLevel] Probe initialization complete!
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Check if provided file exists
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Check if provided file can be read
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Detecting package components","operation":"confirm_image","progressPercentage":25,"step":1}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Verifying that package is complete","operation":"confirm_image","progressPercentage":50,"step":2}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Detecting bootloader version","operation":"confirm_image","progressPercentage":75,"step":3}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":4,"description":"Finding image components","duration":0,"message":"Finished","operation":"confirm_image","progressPercentage":100,"result":"success","step":4}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":7,"description":"Upload segments","duration":0,"message":"Prepare modem for upload","operation":"enter_programming_state","progressPercentage":14,"step":1}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":7,"description":"Upload segments","duration":0,"message":"Upload bootloader","operation":"enter_programming_state","progressPercentage":28,"step":2}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":2,"description":"Starting modem boot loader","duration":0,"message":"mfw_nrf9160_1.3.7/72B3D7C.ipc_dfu.signed_1.2.0.ihex","operation":"enter_programming_state","progressPercentage":50,"step":1}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Extracting 16791 bytes from mfw_nrf9160_1.3.7/72B3D7C.ipc_dfu.signed_1.2.0.ihex.
    "duration": 0,
    "message": "Calculating image size",
    "operation": "upload_image",
    "progress_percentage": 5
    "duration": 0,
    "message": "Uploading image to device",
    "duration": 8,
    "progress_percentage": 14
    "duration": 16,
    "progress_percentage": 19
    "duration": 25,
    "progress_percentage": 24
    "duration": 33,
    "progress_percentage": 28
    "duration": 42,
    "progress_percentage": 33
    "duration": 50,
    "progress_percentage": 38
    "duration": 59,
    "progress_percentage": 43
    "duration": 67,
    "progress_percentage": 48
    "duration": 76,
    "progress_percentage": 53
    "duration": 84,
    "progress_percentage": 58
    "duration": 93,
    "progress_percentage": 63
    "duration": 101,
    "progress_percentage": 68
    "duration": 110,
    "progress_percentage": 73
    "duration": 118,
    "progress_percentage": 78
    "duration": 127,
    "progress_percentage": 83
    "duration": 135,
    "progress_percentage": 88
    "duration": 144,
    "progress_percentage": 93
    "duration": 152,
    "progress_percentage": 98
    "duration": 212,
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":2,"description":"Starting modem boot loader","duration":213,"message":"Finished","operation":"enter_programming_state","progressPercentage":100,"result":"success","step":2}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":7,"description":"Upload segments","duration":213,"message":"Modem ready for upload","operation":"enter_programming_state","progressPercentage":42,"step":3}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] {"amountOfSteps":7,"description":"Upload segments","duration":0,"message":"segment 1 of 4","operation":"upload_image","progressPercentage":57,"step":4}
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Extracting 212 bytes from __MACOSX/mfw_nrf9160_1.3.7/._firmware.update.image.segments.0.hex.
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Unknown runtime error: Found end of content before end of string.
[HighLevel] Failed programming the device.
[Probes./dev/tty.usbserial-510] b"An error was reported by NRFJPROG DLL: -254 INTERNAL_ERROR. \n[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Error caught in parse_stat_response: Key not found: 'rc'\n\textra: [Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Unknown runtime error: Found end of content before end of string.\n\textra: [HighLevel] Failed programming the device."
[Probes./dev/tty.usbserial-510] [ModemUARTDFUProbe] Uninitializing ModemUARTDFU probe at serial port /dev/tty.usbserial-510.
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Sending device reset request
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Sending reset request to device.
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] Closing connection to mcuboot device
[Probes./dev/tty.usbserial-510] [ModemUARTDFU-/dev/tty.usbserial-510] serial port /dev/tty.usbserial-510 closed.
    "duration": 74,
    "error_code": "Ok",
    "operation": "close_uart",
[HighLevel] Done.
  File "/Users/robert/src/zephyr/circuitdojo/proj2/nfed/samples/mfw_update/update_modem.py", line 43, in <module>
  File "/Users/robert/src/zephyr/circuitdojo/proj2/nfed/samples/mfw_update/update_modem.py", line 26, in run
    modem_dfu_probe.program(modem_firmware_zip)
  File "/Users/robert/.virtualenvs/zephyr/lib/python3.11/site-packages/pynrfjprog/HighLevel.py", line 409, in program
pynrfjprog.APIError.APIError: An error was reported by NRFJPROG DLL: -254 INTERNAL_ERROR.
