Wondering which pins allow PWM. I’d also like to know what voltage and how many milli-amps will be output with
100% duty cycle.
I would assume it is 3.3V.
Anyone that can lend a hand, I would greatly appreciate it.
Thanks,
Jerrad
@jhox616 as far as I know you can select any pin. The only limitation is the PWM peripheral only supports up to 4 GPIOs at one time. And yes, 100% duty cycle should be 3.3V on the nRF9160 Feather.
Thank you so much Jared for the fast response. Hope you are doing well.
