intelcomdk After upgrade from 2.9.0 to 2.9.1 I can’t get the my blinky to compile (regular blinky program with i2c enabled etc.). errors: zephyr\zephyr_pre0.elf section datas' will not fit in regionFLASH’ region `FLASH’ overflowed by 160 bytes MCU bootloader is enabled. It compiles and runs on a nrf9160DK. I assume default partitioning should be changed?
intelcomdk problem solved by myself. Copied board files for version 2.7.0 from github, and copied to boards folder on nrf connect sdk 2.9.1 boards folder, and then it all worked again.
