I am trying to program the certificates on the nRF9151 Feather using Nordic Certificate Manager but it is failing with the error Unable to Write TLS credential
I am running the AT Client sample and I have put the nRF9151 Feather in offline mode using AT+CFUN=4
I have tried to write the certificates using the both the Serial Terminal and ExtraPutty but it seems to get the line endings wrong and even though it says OK I can see the hashes when looking at the results of AT%CMNG=1 are incorrect and the device does not connect to the Azure IoT Hub
I have seen the instructions for the nRF9160 Feather to use the old LTE Link Monitor/Certificate manager so I can see it was working for that device
I have found updating the certificates did not work using the 2.0.2 modem firmware and I had to downgrade to 2.0.0 to get these commands to work.  The commands were failing with CME ERROR 527 on 2.0.2 modem firmware e.g.
AT%CMNG=0,77,1,"—–BEGIN CERTIFICATE—–
—–END CERTIFICATE—–"
