Trying to get the accelerometer example up and running on the feather, however, it fails to compile.
Can you help as to why the driver is complaining?
The logs are attached below:
`-- west build: building application
[1/172] Preparing syscall dependency handling
[12/172] Performing build step for 'spm_subimage'
[1/197] Preparing syscall dependency handling
[192/197] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 32256 B 48 KB 65.62%
SRAM: 5520 B 64 KB 8.42%
IDT_LIST: 40 B 2 KB 1.95%
[197/197] Linking C executable zephyr/zephyr.elf
[18/172] Performing build step for 'mcuboot_subimage'
[1/179] Preparing syscall dependency handling
[174/179] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 42076 B 48 KB 85.60%
SRAM: 22176 B 192 KB 11.28%
IDT_LIST: 72 B 2 KB 3.52%
[179/179] Linking C executable zephyr/zephyr.elf
[30/172] Building C object CMakeFiles/app.dir/src/main.c.obj
FAILED: CMakeFiles/app.dir/src/main.c.obj
/opt/nordic/ncs/v1.4.1/toolchain/bin/arm-none-eabi-gcc -DBUILD_VERSION=v2.4.0-ncs2 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DNRF9160_XXAA -DNRF_TRUSTZONE_NONSECURE -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=2 -D__PROGRAM_START -D__ZEPHYR__=1 -I/opt/nordic/ncs/v1.4.1/zephyr/include -Izephyr/include/generated -I/opt/nordic/ncs/v1.4.1/zephyr/soc/arm/nordic_nrf/nrf91 -I/opt/nordic/ncs/v1.4.1/nrf/include -I/opt/nordic/ncs/v1.4.1/nfed/include -I/opt/nordic/ncs/v1.4.1/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v1.4.1/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v1.4.1/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v1.4.1/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v1.4.1/modules/hal/nordic/. -isystem /opt/nordic/ncs/v1.4.1/zephyr/lib/libc/minimal/include -isystem /opt/nordic/ncs/v1.4.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/include -isystem /opt/nordic/ncs/v1.4.1/toolchain/bin/../lib/gcc/arm-none-eabi/9.2.1/include-fixed -Os -imacros /opt/nordic/ncs/v1.4.1/nfed/samples/accelerometer/build/zephyr/include/generated/autoconf.h -ffreestanding -fno-common -g -mcpu=cortex-m33 -mthumb -mabi=aapcs -imacros /opt/nordic/ncs/v1.4.1/zephyr/include/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-main -Wno-pointer-sign -Wpointer-arith -Wno-address-of-packed-member -Wno-unused-but-set-variable -Werror=implicit-int -fno-asynchronous-unwind-tables -fno-pie -fno-pic -fno-strict-overflow -fno-reorder-functions -fno-defer-pop -fmacro-prefix-map=/opt/nordic/ncs/v1.4.1/nfed/samples/accelerometer=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v1.4.1/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v1.4.1=WEST_TOPDIR -ffunction-sections -fdata-sections -std=c99 -nostdinc -MD -MT CMakeFiles/app.dir/src/main.c.obj -MF CMakeFiles/app.dir/src/main.c.obj.d -o CMakeFiles/app.dir/src/main.c.obj -c ../src/main.c
In file included from /opt/nordic/ncs/v1.4.1/zephyr/include/arch/arm/aarch32/arch.h:20,
from /opt/nordic/ncs/v1.4.1/zephyr/include/arch/cpu.h:19,
from /opt/nordic/ncs/v1.4.1/zephyr/include/kernel_includes.h:38,
from /opt/nordic/ncs/v1.4.1/zephyr/include/kernel.h:17,
from /opt/nordic/ncs/v1.4.1/zephyr/include/zephyr.h:18,
from ../src/main.c:8:
../src/main.c: In function 'main':
/opt/nordic/ncs/v1.4.1/zephyr/include/devicetree.h:297:40: error: 'DT_N_INST_0_st_lis2dh_P_label' undeclared (first use in this function)
297 | #define DT_INST(inst, compat) UTIL_CAT(DT_N_INST, DT_DASH(inst, compat))
/opt/nordic/ncs/v1.4.1/zephyr/include/devicetree.h:1911:38: note: in definition of macro 'DT_CAT'
1911 | #define DT_CAT(node_id, prop_suffix) node_id##prop_suffix
/opt/nordic/ncs/v1.4.1/zephyr/include/devicetree.h:496:27: note: in expansion of macro 'DT_PROP'
496 | #define DT_LABEL(node_id) DT_PROP(node_id, label)
../src/main.c:59:54: note: in expansion of macro 'DT_LABEL'
59 | const struct device *sensor = device_get_binding(DT_LABEL(DT_INST(0, st_lis2dh)));
/opt/nordic/ncs/v1.4.1/zephyr/include/sys/util_internal.h:105:26: note: in expansion of macro 'UTIL_PRIMITIVE_CAT'
105 | #define UTIL_CAT(a, ...) UTIL_PRIMITIVE_CAT(a, __VA_ARGS__)
/opt/nordic/ncs/v1.4.1/zephyr/include/devicetree.h:297:31: note: in expansion of macro 'UTIL_CAT'
../src/main.c:59:63: note: in expansion of macro 'DT_INST'
/opt/nordic/ncs/v1.4.1/zephyr/include/devicetree.h:297:40: note: each undeclared identifier is reported only once for each function it appears in
[34/172] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /opt/nordic/ncs/v1.4.1/nfed/samples/accelerometer/build
Thanks
