I am using FOTA on the nrf9160 to upgrade the firmware from a file on my AWS server. Invariably, the session needs to log back in. Occasionally, it fails. Can I do any throttling or something to prevent this issue. I need to get 100% assured upgrade when I start the process.
D: Receiving up to 2048 bytes at 0x200226ec...
D: Read 533 bytes from socket
D: GET header size: 533
D: Read 1024 bytes from socket
D: Receiving up to 1024 bytes at 0x20022aec...
I: Downloaded 221184/230468 bytes (95%)
fota_dl_handler: prog 95
check_to_update_progress: 95, 100
LED: 0
D: Read 552 bytes from socket
D: GET header size: 552
W: Peer closed connection, will re-connect
I: Downloaded 223232/230468 bytes (96%)
I: Erasing page at offset 0x000be000
fota_dl_handler: prog 96
check_to_update_progress: 96, 100
LED: 1
I: Reconnecting..
download_client_connect : 1
download_client_connect AF_INET : ps-gateway-firmware.s3.us-west-1.amazonaws.com
download_client_connect : 2
download_client_connect : 3
D: Protocol not specified, defaulting to HTTP(S)
D: Port not specified, using default: 443
D: family: 1, type: 1, proto: 258
I: Setting up TLS credentials, tag 1
I: Connecting to ps-gateway-firmware.s3.us-west-1.amazonaws.com
D: fd 2, addrlen 8, fam IPv4, port 443
D: fd 2, addrlen 8, fam IPv4, ip 52.219.220.146, port 443
D: Read 513 bytes from socket
D: GET header size: 513
I: Downloaded 225280/230468 bytes (97%)
fota_dl_handler: prog 97
check_to_update_progress: 97, 100
LED: 0
I: Downloaded 227328/230468 bytes (98%)
I: Erasing page at offset 0x000bf000
fota_dl_handler: prog 98
check_to_update_progress: 98, 100
LED: 1
D: Read 2048 bytes from socket
I: Downloaded 229376/230468 bytes (99%)
fota_dl_handler: prog 99
check_to_update_progress: 99, 100
LED: 0
client_write: err 0
**** polling loop
D: Read 1092 bytes from socket
I: Downloaded 230468/230468 bytes (100%)
I: Erasing page at offset 0x000c0000
mqtt_handle_packet 208
[mqtt_evt_handler:413] mqtt_evt_handler (9)!
MQTT PINGRESP
**** polling loop
LED: 1
I: Download complete
