no spaces in any path. Did a clean build and issue still there. Appears to be configuration error:
* Executing task: nRF Connect: Generate config circuitdojo_feather_nrf9151/nrf9151/ns for /opt/PWL
Building PWL
west build --build-dir /opt/PWL/build /opt/PWL --pristine --board circuitdojo_feather_nrf9151/nrf9151/ns --sysbuild -- -DCONFIG_DEBUG_THREAD_INFO=y
Loading Zephyr module(s) (Zephyr base): sysbuild_default
-- Found Python3: /opt/nordic/ncs/toolchains/322ac893fe/opt/python@3.12/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Cache files will be written to: /Users/summer/Library/Caches/zephyr
-- Found west (found suitable version "1.4.0", minimum required is "0.14.0")
-- Board: circuitdojo_feather_nrf9151, Revision: 1, qualifiers: nrf9151/ns
Parsing /opt/nordic/zephyr/share/sysbuild/Kconfig
Loaded configuration '/opt/PWL/build/_sysbuild/empty.conf'
Merged configuration '/opt/PWL/build/_sysbuild/empty.conf'
Merged configuration '/opt/PWL/sysbuild.conf'
Configuration saved to '/opt/PWL/build/zephyr/.config'
Kconfig header saved to '/opt/PWL/build/_sysbuild/autoconf.h'
-- Sysbuild assigned MCUboot image IDs:
* Application: 0
* Running CMake for mcuboot *
-- Application: /opt/nordic/bootloader/mcuboot/boot/zephyr
-- CMake version: 3.21.0
-- Found Python3: /opt/nordic/ncs/toolchains/322ac893fe/bin/python (found suitable version "3.12.4", minimum required is "3.10") found components: Interpreter
-- Zephyr version: 4.2.99 (/opt/nordic/zephyr)
-- Found host-tools: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/322ac893fe/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.17.0 (/opt/nordic/ncs/toolchains/322ac893fe/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/322ac893fe/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/nfed/boards/circuitdojo/feather_nrf9151/circuitdojo_feather_nrf9151.dts
-- Found devicetree overlay: /opt/nordic/bootloader/mcuboot/boot/zephyr/app.overlay
-- Generated zephyr.dts: /opt/PWL/build/mcuboot/zephyr/zephyr.dts
-- Generated pickled edt: /opt/PWL/build/mcuboot/zephyr/edt.pickle
-- Generated devicetree_generated.h: /opt/PWL/build/mcuboot/zephyr/include/generated/zephyr/devicetree_generated.h
warning: UART_CONSOLE (defined at drivers/console/Kconfig:42) was assigned the value 'y' but got the
warning: I2C (defined at drivers/i2c/Kconfig:9) was assigned the value 'n' but got the value 'y'.
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_I2C and/or look up I2C in the
menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values,
Parsing /opt/nordic/bootloader/mcuboot/boot/zephyr/Kconfig
Loaded configuration '/opt/nordic/nfed/boards/circuitdojo/feather_nrf9151/circuitdojo_feather_nrf9151_defconfig'
Merged configuration '/opt/nordic/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/opt/PWL/sysbuild/mcuboot.conf'
Merged configuration '/opt/nordic/nrf/modules/mcuboot/tfm.conf'
Merged configuration '/opt/PWL/build/mcuboot/zephyr/.config.sysbuild'
Configuration saved to '/opt/PWL/build/mcuboot/zephyr/.config'
Kconfig header saved to '/opt/PWL/build/mcuboot/zephyr/include/generated/zephyr/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/322ac893fe/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/322ac893fe/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Using ccache: /opt/nordic/ncs/toolchains/322ac893fe/bin/ccache
-- Found gen_kobject_list: /opt/nordic/zephyr/scripts/build/gen_kobject_list.py
CMake Warning at /opt/nordic/zephyr/CMakeLists.txt:1096 (message):
No SOURCES given to Zephyr library:
..__nfed__boards__circuitdojo__feather_nrf9151
Excluding target from build.
MCUBoot bootloader key file: /opt/nordic/bootloader/mcuboot/root-ec-p256.pem
CMake Warning at CMakeLists.txt:442 (message):
WARNING: Using default MCUboot signing key file, this file is for debug use
only and is not secure!
-- Configuring done
-- Generating done
-- Build files have been written to: /opt/PWL/build/mcuboot
* Running CMake for PWL *
-- Application: /opt/PWL
-- Found BOARD.dts: /opt/nordic/nfed/boards/circuitdojo/feather_nrf9151/circuitdojo_feather_nrf9151_ns.dts
-- Found devicetree overlay: /opt/PWL/boards/circuitdojo_feather_nrf9151_ns.overlay
-- Generated zephyr.dts: /opt/PWL/build/PWL/zephyr/zephyr.dts
-- Generated pickled edt: /opt/PWL/build/PWL/zephyr/edt.pickle
-- Generated devicetree_generated.h: /opt/PWL/build/PWL/zephyr/include/generated/zephyr/devicetree_generated.h
warning: UPDATEABLE_IMAGE_NUMBER (defined at
/opt/nordic/nrf/modules/../samples/common/mcumgr_bt_ota_dfu/Kconfig:87, subsys/dfu/Kconfig:96) was
assigned the value '1' but got the value ''. Check these unsatisfied dependencies:
(((BOARD_THINGY53_NRF5340_CPUAPP || BOARD_THINGY53_NRF5340_CPUAPP_NS) && SOC_SERIES_NRF53X &&
NCS_SAMPLE_MCUMGR_BT_OTA_DFU) || (!MCUBOOT && IMG_MANAGER)) (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UPDATEABLE_IMAGE_NUMBER and/or look up
UPDATEABLE_IMAGE_NUMBER in the menuconfig/guiconfig interface. The Application Development Primer,
Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
helpful too.
warning: MCUBOOT_UPDATE_FOOTER_SIZE (defined at subsys/dfu/Kconfig:55) was assigned the value
'0x2000' but got the value ''. Check these unsatisfied dependencies: MCUBOOT_IMG_MANAGER (=n),
IMG_MANAGER (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_UPDATE_FOOTER_SIZE and/or look up
MCUBOOT_UPDATE_FOOTER_SIZE in the menuconfig/guiconfig interface. The Application Development
Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual
Parsing /opt/nordic/zephyr/Kconfig
Loaded configuration '/opt/nordic/nfed/boards/circuitdojo/feather_nrf9151/circuitdojo_feather_nrf9151_ns_defconfig'
Merged configuration '/opt/PWL/prj.conf'
Merged configuration '/opt/PWL/boards/circuitdojo_feather_nrf9151_ns.conf'
Merged configuration '/opt/PWL/build/PWL/zephyr/misc/generated/extra_kconfig_options.conf'
Merged configuration '/opt/PWL/build/PWL/zephyr/.config.sysbuild'
**-- Configuring incomplete, errors occurred!**
/opt/PWL/prj.conf:96: warning: attempt to assign the value 'y' to the undefined symbol LED_NPM1300
/opt/PWL/boards/circuitdojo_feather_nrf9151_ns.conf:2: warning: attempt to assign the value 'y' to the undefined symbol MFD_NPM1300
CMake Error at /opt/nordic/zephyr/cmake/modules/kconfig.cmake:387 (message):
/opt/nordic/nrf/cmake/modules/kconfig.cmake:112 (include)
/opt/nordic/zephyr/cmake/modules/zephyr_default.cmake:131 (include)
/opt/nordic/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
/opt/nordic/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:6 (find_package)
CMake Error at cmake/modules/sysbuild_extensions.cmake:530 (message):
CMake configure failed for Zephyr project: PWL
cmake/modules/sysbuild_images.cmake:43 (ExternalZephyrProject_Cmake)
cmake/modules/sysbuild_default.cmake:21 (include)
/opt/nordic/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:75 (include)
/opt/nordic/zephyr/share/sysbuild-package/cmake/SysbuildConfig.cmake:8 (include)
template/CMakeLists.txt:10 (find_package)
See also "/opt/PWL/build/CMakeFiles/CMakeOutput.log".
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/322ac893fe/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/322ac893fe/opt/python@3.12/bin/python3.12 -B/opt/PWL/build -GNinja -DBOARD=circuitdojo_feather_nrf9151/nrf9151/ns -DCONFIG_DEBUG_THREAD_INFO=y -S/opt/nordic/zephyr/share/sysbuild -DAPP_DIR:PATH=/opt/PWL
* The terminal process terminated with exit code: 1.
