The nfed samples are great but I need an AT interface - I can’t setup a SIM card unless I know the IMEI, if there was one in the box I can’t find it now. I’ve been waiting on the V people but I’ll try another vendor.
I’ve found I can erase the feather, program the bootloader then add the serial_lte_modem from ncs/v1.4.1/nrf/applications/serial_lte_modem here is the modified prj.conf:
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# General config
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_STACK_SENTINEL=y
CONFIG_NEWLIB_LIBC=y
CONFIG_RING_BUFFER=y
# Segger RTT
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_BACKEND_UART=n
# Network
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_NATIVE=n
# BSD library
CONFIG_BSD_LIBRARY=y
# Align the max FD entry to BSD_MAX_SOCKET_COUNT(8)
CONFIG_POSIX_MAX_FDS=8
# Enable below for modem trace
#CONFIG_BSD_LIBRARY_TRACE_ENABLED=y
# Use GPIO
CONFIG_GPIO=y
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRF_P0=y
# UART interface
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
CONFIG_NRFX_TIMER2=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
# Stacks and heaps
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
# AT_CMD
# Enable AT_CMD debug for details
#CONFIG_AT_CMD_LOG_LEVEL_DBG=y
# Device power management
CONFIG_DEVICE_POWER_MANAGEMENT=y
# Enable SUPL client support
#CONFIG_SUPL_CLIENT_LIB=y
# FOTA
CONFIG_HTTP_PARSER_URL=y
CONFIG_FOTA_DOWNLOAD=y
CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
CONFIG_DFU_TARGET=y
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
CONFIG_IMG_MANAGER=y
CONFIG_FLASH=y
# Application-specific
CONFIG_SLM_LOG_LEVEL_INF=y
# Enable GPIO wakeup if sleep is expected
#CONFIG_SLM_GPIO_WAKEUP=y
# Use UART_0 (when working with PC terminal)
CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
# Use UART_2 (when working with external MCU)
#CONFIG_SLM_CONNECT_UART_2=y
#CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
# Use optional TCP/TLS Proxy
#CONFIG_SLM_TCP_PROXY=y
# Use optional UDP/DTLS Proxy
#CONFIG_SLM_UDP_PROXY=y
When it is done I use the bootloader to install it. I’ve done this a few times now, the last time I removed the TC2030 from the feather before loading the SLM bin.
Question, how do you ‘clean’ the build files? cmake and west do not seem to have a ‘–clean ’
