I’ve bricked my nRF9151 Feather after testing Zephyr’s sys_poweroff() and I’ve exhausted every recovery method I can find.
What happened:
- Flashed a test firmware that calls sys_poweroff() with GPIO wake (DS3231 RTC alarm on P0.27). System Off + alarm wake was working correctly.
- Flashed the production firmware (uses k_sleep(), does NOT call sys_poweroff()).
- Connected the Arducam camera VCC to the 3.3V header pin — board immediately went dead on USB.
- Briefly saw “RPI-RP2” disk notifications (BOOTSEL mode) when power cycling, but the RP2040 disconnected too fast to flash debugprobe.uf2.
- After several recovery attempts, the RP2040 stopped appearing entirely. No USB enumeration at all — not as CMSIS-DAP, not as RPI-RP2, nothing.
What I’ve tried:
- Every BOOTSEL sequence (BS held while plugging in, various timing)
- probe-rs erase –chip nRF9151_xxAA –allow-erase-all in a tight loop
- picotool load in a tight loop
- Raw libusb detection + UF2 write (found device once but it disappeared before write completed)
- Circuit Dojo recovery tool with 60s timeout
- Pulling EN pin to GND, to 3.3V, and to VBUS — with and without battery
- Full power drain (USB + battery disconnected, 60+ seconds)
- All three buttons in various combinations
Board state:
- No battery connected
- All external peripherals disconnected (camera, DS3231 RTC)
- USB cable and port confirmed working (other devices enumerate fine)
- system_profiler SPUSBDataType shows zero USB devices from the board
- macOS system log shows no USB attach/detach events
My (Claude’s) theory: The nPM1300 PMIC entered ship mode or a latched fault state (possibly overcurrent protection from the camera connection). The RP2040 has no power since it’s fed through BUCK1 → TPS22919, not directly from USB VBUS.
Questions:
- Is there a way to force the nPM1300 out of this state without external hardware? (All I have is basic feather)
- Are the SWD test pads (TP1/TP2 on the schematic) accessible for direct nRF9151 programming with an external probe?
- Any other recovery method I’m missing?
Board purchased March 2026, using NCS v2.9.0.
Thanks for any help
