I’ve got a question about power management on the design…
If the feather is connected by battery via the onboard 2-pin, JST connector, it requires the MODE button to be pressed to power on.
Is there anyway to make it auto-power on, when the battery is connected without having to press MODE ?
Tying EN to 0V or BAT doesn’t seem to do the trick. Also, tying MODE to BAT, although that works, the mode button (for entering DFU) ceases to work, it also shorts the switch and the MODE switch.
Only other possible is the RTC, but as that’s off when the battery is disconnected, I’m guessing it would lose it’s settings. I’m sure I’m missing something somewhere.
