Hi there,
I’d like to use the Circuit Dojo nRF9151 for a project of mine in order to avoid making my own board.
My goal is an 8-10 year device lifetime with a primary cell, however I see that the nRF9151 Feather uses a Nordic PMIC designed primarily for secondary batteries that are not quite in line with my use case.
If I designed my own board, I would likely choose an LiSOCl2 battery along with a TI TPS63900.
I understand the nRF9151 feather has a 2W power requirement which my LiSOCl2 battery of choice (Jauch 18505) cannot support out of the box.
Are there any recommended primary batteries or power strategies to take advantage of the Circuit Dojo nRF9151 Feather in a years-long use case?
Thank you!
Sage
