Hi Jared and all,
The Recovery & Programming Mini Fixture is currently out of stock, so I’d like to build one myself from the open-source files on GitHub (nrf91xx-feather-recovery-fixture). Thanks for sharing the design!
I couldn’t find the pogo pin part number anywhere. In the schematic, J3–J8 use the generic footprint TestPoint_THTPad_D2.5mm_Drill1.2mm and the “Circuit Dojo PN” field is empty. The BOM folder only contains ibom.html.
Could you share:
- The manufacturer and part number of the pogo pins (P75 series?)
- The pin length and travel you used, so the board sits at the right height in the 3D-printed part
- The head type. From the PCB, GND/VCC/nRST (J6/J3/J8) seem to land on the header through-holes, while SWDIO/SWCLK (J4/J5) land on pads. Do you use the same head (e.g. crown) for all six, or different ones?
