Hello!
I’ve been working with the nRF9160 feather for a while now so I mostly manage to work my way around certain errors. However, I decided to get a new computer so I have to reinstall SDK. Note that most of the code I’ve done has been in 1.3.2, and since I have not ported to code to a newer version this is the current zephyr version I’m using.
I followed the steps from the docs and managed to download the 1.3.2 modified version of the nRF connect SDK. But for some reason the circuitdojo_feather_nrf9160 nor the NS version are in the “zephyr -> boards -> arm” folder. I’m not certain what kind of information is needed to fix this issue, so I will wait for a response and provide what is needed thereafter.
    jaredwolff Yes, now everything is working just fine! I want to note that the first time I uploaded my code the feather turned into a “brick” state. couldn’t even upload new code with the tag-connect or put it in MCBoot mode. However, I did manage to update the modem firmware through the tag-connect and then reupload the code and everything started to work.
