Just tried it here and I'm getting the same error. Must have something to do with the version of the toolchain. We may need to regress. Let me figure out how to get an older version with brew
no did not do any modifications except adding MCUBoot support.
anyways here is the prj.conf
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
CONFIG_BSD_LIBRARY=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEWLIB_LIBC=y
CONFIG_AT_CMD=y
CONFIG_AT_NOTIF=y
# Enable SUPL client support
CONFIG_SUPL_CLIENT_LIB=n
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Disable native network stack to save some memory
CONFIG_NET_NATIVE=n
# Main thread
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_MAIN_STACK_SIZE=4096
# COEX0 is used to enable the GPS LNA, but it has to be configured to do so.
CONFIG_NRF9160_GPS_SET_COEX0=y
CONFIG_AT_CMD_PARSER=y
CONFIG_NRF9160_GPS_HANDLE_MODEM_CONFIGURATION=y
CONFIG_NRF9160_GPS=y
CONFIG_NRF9160_GPS_COEX0_STRING="AT%XCOEX0=1,1,1565,1586"
and this is the CMakeLists.txt
cmake_minimum_required(VERSION 3.8.2)
#find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
find_package(Zephyr HINTS $ENV{ZEPHYR_BASE})
project(gps_socket_sample)
zephyr_library_sources(src/main.c)
zephyr_library_sources_ifdef(
  src/supl_support.c
Yes that link I saw ... but how can I pass these options to the linker ?
    lbh00 Yes that link I saw ... but how can I pass these options to the linker ?
    You shouldn't have to. It compiled fine before I ... optimized the OSX install. πŸ™
      ok so now you also have the same issue ?
      I recall having a similar issue in an older sdk... and the only way it was solved for me was with a new sdk(1.3).
      Here are the steps to fix this:
      1. First uninstall gcc-arm-embedded from brew
           brew uninstall gcc-arm-embedded
      2. Install the toolchain by pulling it from ARM. Run these commands:
           cd ~
           wget "https://developer.arm.com/-/media/Files/downloads/gnu-rm/9-2019q4/gcc-arm-none-eabi-9-2019-q4-major-mac.tar.bz2"
           tar xvfj gcc-arm-none-eabi-9-2019-q4-major-mac.tar.bz2
           rm gcc-arm-none-eabi-9-2019-q4-major-mac.tar.bz2
        Note for Catalina users you will get an error when running these utilities for the first time. You must allow them to be executed in your Security preferences.
        Error running ARM Toolchain
      3. Finally you'll need export a few important environment variables for things to work. For bash here's the entry for .bash_profile that I have:
           # Zephyr related
           export ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
           export GNUARMEMB_TOOLCHAIN_PATH="~/gcc-arm-none-eabi-9-2019-q4-major"
        πŸ’‘Note: this should also work for .zshrc for those folks who are using newer versions of Mac OS (or just plain prefer zsh)
        For folks using fish you're going to use:
           set -Ux ZEPHYR_TOOLCHAIN_VARIANT gnuarmemb
           set -Ux GNUARMEMB_TOOLCHAIN_PATH "~/gcc-arm-none-eabi-9-2019-q4-major"
      4. Close and reopen all terminals and Visual Studio Code.
      5. Try compiling again!
      Also remove any reference to CROSS_COMPILE in you .zshrc or .bash_profile or remove it in fish using set -e CROSS_COMPILE
      Hello,
      Ok this solved the initial issue.
      However now I have something like this error for some .h files
      #include errors detected. Please update your includePath. Squiggles are disabled for this translation unit (/Users/louis/ncs/nrf/samples/nrf9160/gps/src/main.c).C/C++(1696)
      cannot open source file "inttypes.h" (dependency of "zephyr.h")C/C++(1696)
      cannot open source file "sys/types.h" (dependency of "nrf_socket.h")C/C++(1696)
      cannot open source file "sys/types.h" (dependency of "net/socket.h")C/C++(1696)
      cannot open source file "stdio.h"C/C++(1696)
      VSC proposes to add them to the IncludePath... shall I do it ? or is it something I can solve in the config files ?
      Regards
      louis.h
      and yes I guess these issues with the header files are causing this error at linking stage
      /Users/louis/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: modules/nrf/drivers/gps/nrf9160_gps/lib..__nrf__drivers__gps__nrf9160_gps.a(nrf9160_gps.c.obj): in function `enable_gps':
      /Users/louis/ncs/nrf/drivers/gps/nrf9160_gps/nrf9160_gps.c:361: undefined reference to `lte_lc_system_mode_get'
      /Users/louis/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: /Users/louis/ncs/nrf/drivers/gps/nrf9160_gps/nrf9160_gps.c:389: undefined reference to `lte_lc_func_mode_get'
      /Users/louis/gcc-arm-none-eabi-9-2019-q4-major/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld: /Users/louis/ncs/nrf/drivers/gps/nrf9160_gps/nrf9160_gps.c:380: undefined reference to `lte_lc_system_mode_set'
      collect2: error: ld returned 1 exit status
      FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /Users/louis/ncs/nrf/samples/nrf9160/gps/build
        lbh00 try removing the build dir:
        rm -rf build
        And try again.
        This is the command I always do
        especially when I have a compilation issue to remove the caches effects
        rm -rf build && rm -rf ~/Library/Caches/zephyr && west build -b circuitdojo_feather_nrf9160ns -p
        lbh00 Can you provide the output of git log -n 1 and git status? (in the gps example directory is fine)
        yes:
        git log -n 1
        commit c2d3f852399c96009677077c166e722ae0a54e5a (HEAD, tag: v1.3.2, origin/v1.3-branch)
        Author: Carles Cufi <carles.cufi@nordicsemi.no>
        Date:   Fri Oct 9 11:32:06 2020 +0200
            manifest: Set sdk-zephyr to v2.3.0-rc1-ncs3
            For the NCS 1.3.2 release, point sdk-zephyr to the corresponding tag.
            Signed-off-by: Carles Cufi <carles.cufi@nordicsemi.no>
        louis@Louiss-MBP gps % git status
        HEAD detached at v1.3.2
        Changes not staged for commit:
          (use "git add <file>..." to update what will be committed)
          (use "git restore <file>..." to discard changes in working directory)
                modified:   ../at_client/prj.conf
                modified:   CMakeLists.txt
                modified:   prj.conf
        Untracked files:
          (use "git add <file>..." to include in what will be committed)
                ../../../.DS_Store
                ../../.DS_Store
                ../.DS_Store
        no changes added to commit (use "git add" and/or "git commit -a")
          lbh00
          git checkout CMakeLists.txt
          (You may have to provide the full path.)
          See here for details.
          did this git checkout HEAD CMakeLists.txt
          but I still have the same linking issue!
          Hello,
          I have just set this config to n
          CONFIG_NRF9160_GPS_HANDLE_MODEM_CONFIGURATION=n
          and the linking was successful.
          I guess this tells it to use the GPS driver ?
          so problem solved and case closed.
          GPS testing started!
