meisner According to this page;
https://docs.zephyrproject.org/latest/boards/arm/particle_argon/doc/index.html
I can use the Particle Argon board, which gets me support for Zephyr and has an ESP32 for WiFi support (again, to transmit data to Home Assistant).
While I haven’t deployed the Argon, you should be able to use the same code that supports the Xenon. Publishing data to something like Golioth & Grafana may be interesting. I’ll have to add this to my list!
meisner From Particle’s site:
https://store.particle.io/products/argon?pos=1&sid=63f274166&_ss=r
The Argon dev board Is available for $28USD and is Feather compatible. So I believe this board will work fine for my use. Would you agree?
Yup! There is a learning curve with Zephyr. If I have time in the coming weeks I’m going to try and smooth the process out a bit. Nordics VSCode extension helps but it doesn’t go as far as what Espressif’s does and actually install the SDK, manage dependencies, etc.
Also meisner I just added some basic display code as well:
Now I just need to figure out an updated enclosure. 😅
meisner I did talk to some folks at Golioth since they have used the nRF52 + ESP32 combo and they had some feedback on the Argon:
I used it, but the process was super cumbersome to update the ESP32 to the right firmware
I can try to get some instructions here and overlay files. But I used a Adafruit tutorial to install CircuitPython with some passthrough firmware to flash the ESP32
It didn’t worked properly with the built in firmware here 😞
So it may not be so straight forward. Proceed with caution. 😅 Maybe something like a Huzzah32 instead?
9 days later
Well … I came back here since I finally received my Argon (and other pieces) and tried to get this working, but have encountered only problems. For some reason I was not being notified of your replies.
Right now, I registered the Argon and have it working with their WebIDE. I can write code in the WebIDE and deploy it to my Argon. But the AQW seems to be having problems. If I set the hpma115 to false in the AirQualityWingSettings_t struct, I do get temp & humidity (although it seems unrealistically high). But when “Has HPMA115” is set to true, I get the following on the debug terminal (yes, I picked up a serial debug module):
Air Quality Wing for Particle Mesh
0000129893 [app] WARN: Error tvoc - no data
0000139894 [app] ERROR: hpma timeout
0000139895 [app] ERROR: Error hpma115
So first of all, it seems as though my Honeywell HPMA115 is not working.
Based on your last reply (and the feedback from Golioth), it feels like I wasted my money (& time) on the Particle Argon board. Would you agree? I can easily pick up a Huzzah32 and continue working on this, but it seems like all of your instructions are based on Particle board usage. I chose the Argon based on your comment “Note: if you’re just starting out, the Argon is your best bet.” on the site https://www.jaredwolff.com/how-to-use-particle-squared-air-quality-sensor/.
Am I missing something here??? I feel like this shouldn’t be this difficult.
Another detail; looking at your photo above, the orientation of the HPMA115 sensor seems to be different than the board I received. Is the one you have in the pic an old one (like a different rev)?
    meisner Well … I came back here since I finally received my Argon (and other pieces) and tried to get this working, but have encountered only problems. For some reason I was not being notified of your replies.
    You may want to check and make sure whatever account you’re using is providing a valid email address. I’m getting notifications on my end.
    meisner Based on your last reply (and the feedback from Golioth), it feels like I wasted my money (& time) on the Particle Argon board.
    It’s not necessarily wasted, but as I mentioned the previous Particle library does not work directly with the latest version of the AQW. The HPMA though should be measuring as that hasn’t changed, so I’m not sure what’s happening there. Are you using your own cable and HPMA?
    The documentation you should be referring to is here: https://docs.jaredwolff.com/air-quality-wing/index.html
    meisner Another detail; looking at your photo above, the orientation of the HPMA115 sensor seems to be different than the board I received. Is the one you have in the pic an old one (like a different rev)?
    This was a prototype board. I ended up flipping the pinout that way no matter what orientation you plug the cable it works every time.
      jaredwolff You may want to check and make sure whatever account you’re using is providing a valid email address
      Nope…it was me! I didn’t know I had to “Follow” or subscribe to this thread. I am used to that automatically happening when you start a topic.
      jaredwolff Are you using your own cable and HPMA?
      Nope…I got the sensor and cable from you when I ordered my AQW. Invoice #: YxnD1TKa.
      I also notice the fan in the sensor never turns on. Is there some debugging I can do with the HPMA to test it separately?
      jaredwolff The documentation you should be referring to is here: https://docs.jaredwolff.com/air-quality-wing/index.html
      OK, I have come across multiple articles, so I will try to follow this one. It sounds as thought using the Zephyr kernel is the recommended way to go? I was trying other paths since it seemed like Zephyr wasn’t the only option…maybe that was my first problem?
      jaredwolff This was a prototype board. I ended up flipping the pinout that way no matter what orientation you plug the cable it works every time.
      Good…just wanted to be sure I was connecting it properly.
        meisner Nope…it was me! I didn’t know I had to “Follow” or subscribe to this thread. I am used to that automatically happening when you start a topic.
        Super weird. It should do that especially if you’re the author. I’ll have to test that on my side.
        meisner Nope…I got the sensor and cable from you when I ordered my AQW. Invoice #: YxnD1TKa.
        Got it. Can you send me a picture of your setup to make sure I assembled the cable correctly? In order to save time on the motor, it only turns on when it takes a measurement.
        meisner OK, I have come across multiple articles, so I will try to follow this one. It sounds as thought using the Zephyr kernel is the recommended way to go? I was trying other paths since it seemed like Zephyr wasn’t the only option…maybe that was my first problem?
        It is. I just updated the documentation a bit to use the VSCode plugin. You should be able to build for the particle_argon target but I have no tested it. You do need an external programmer for it to work. (A nRF52 DK works fine)
          jaredwolff Got it. Can you send me a picture of your setup to make sure I assembled the cable correctly? In order to save time on the motor, it only turns on when it takes a measurement.
          Here’s the cable, sensor, Argon and AQW. Hopefully it shows what you needed.
          jaredwolff It is. I just updated the documentation a bit to use the VSCode plugin. You should be able to build for the particle_argon target but I have no tested it. You do need an external programmer for it to work. (A nRF52 DK works fine)
          I just placed an order for an nRF52 DK from Digikey … so when I get that, I will give it a try. In the meantime, review the page you mentioned and start assembling my Zephyr dev environment. Does the VSCode plugin also require a Zephyr cross-compile setup? I am referring to this page; https://docs.zephyrproject.org/latest/boards/arm/particle_argon/doc/index.html#programming-and-debugging
            meisner Here’s the cable, sensor, Argon and AQW. Hopefully it shows what you needed.
            Looks great!
            I did notice though that you’re trying to insert the Argon on the pins. You’re not going to make a good connection here and things will likely not work the way you expect. I suggest putting female headers on the AQW if you want to do this.
            (if all the pins are soldered, disregard. I simply can’t see the underside!)
            meisner I just placed an order for an nRF52 DK from Digikey … so when I get that, I will give it a try. In the meantime, review the page you mentioned and start assembling my Zephyr dev environment. Does the VSCode plugin also require a Zephyr cross-compile setup? I am referring to this page;
            It installs everything for you including the toolchain for ARM devices. So you should be good to go!
              Steve
                    Got it!
                        jaredwolff You’ll need to use Segger RTT for the particle boards.
                        OK thanks for all the help so far Jared, but I need to take a different path here. It seems like at many turns I need to buy another piece of HW or spend a good deal of time learning something I had no interest in. My goal was air quality info to be sent via MQTT. I have gone down so many tangential paths that this is taking too much time.
                        jaredwolff By the way here’s a link to getting half of the equation for Zephyr on an Argon:
                        Yes…even this article you cited is about replacing the stock firmware with CircuitPython … already saw this and determined, “Nope…don’t want to go down that path.”
                        Instead, I am looking at my first idea of using the AQW with an Adafruit Feather (with wifi support) and the Arduino IDE. I just need to understand the AQW interface & API better now.
                          meisner Instead, I am looking at my first idea of using the AQW with an Adafruit Feather (with wifi support) and the Arduino IDE. I just need to understand the AQW interface & API better now.
                          Got it. Sorry it’s taking longer than expected. I have a Huzzah32 here. Let me see if I can get the AQW code working on it. I’ll likely be able to get it working with Golioth fairly easily if you’re open to using something like that. They have a generous dev tier which is sufficient if you’re doing this for hobby purposes.
                          6 days later
                          OK…success!
                          I have had the AQW running (in the 3D printed enclosure you designed) for most of the day today using the HUZZAH32 and the Arduino IDE. Here’s the project:
                          https://github.com/smeisner/AirQualityWing
                          Let me know if you have any thoughts. This is the first version of the code, so improvements would be welcomed!! There is a “to do” list at the end of the README as well.
