meisner Well … I came back here since I finally received my Argon (and other pieces) and tried to get this working, but have encountered only problems. For some reason I was not being notified of your replies.
You may want to check and make sure whatever account you’re using is providing a valid email address. I’m getting notifications on my end.
meisner Based on your last reply (and the feedback from Golioth), it feels like I wasted my money (& time) on the Particle Argon board.
It’s not necessarily wasted, but as I mentioned the previous Particle library does not work directly with the latest version of the AQW. The HPMA though should be measuring as that hasn’t changed, so I’m not sure what’s happening there. Are you using your own cable and HPMA?
The documentation you should be referring to is here: https://docs.jaredwolff.com/air-quality-wing/index.html
meisner Another detail; looking at your photo above, the orientation of the HPMA115 sensor seems to be different than the board I received. Is the one you have in the pic an old one (like a different rev)?
This was a prototype board. I ended up flipping the pinout that way no matter what orientation you plug the cable it works every time.
    jaredwolff You may want to check and make sure whatever account you’re using is providing a valid email address
    Nope…it was me! I didn’t know I had to “Follow” or subscribe to this thread. I am used to that automatically happening when you start a topic.
    jaredwolff Are you using your own cable and HPMA?
    Nope…I got the sensor and cable from you when I ordered my AQW. Invoice #: YxnD1TKa.
    I also notice the fan in the sensor never turns on. Is there some debugging I can do with the HPMA to test it separately?
    jaredwolff The documentation you should be referring to is here: https://docs.jaredwolff.com/air-quality-wing/index.html
    OK, I have come across multiple articles, so I will try to follow this one. It sounds as thought using the Zephyr kernel is the recommended way to go? I was trying other paths since it seemed like Zephyr wasn’t the only option…maybe that was my first problem?
    jaredwolff This was a prototype board. I ended up flipping the pinout that way no matter what orientation you plug the cable it works every time.
    Good…just wanted to be sure I was connecting it properly.
      meisner Nope…it was me! I didn’t know I had to “Follow” or subscribe to this thread. I am used to that automatically happening when you start a topic.
      Super weird. It should do that especially if you’re the author. I’ll have to test that on my side.
      meisner Nope…I got the sensor and cable from you when I ordered my AQW. Invoice #: YxnD1TKa.
      Got it. Can you send me a picture of your setup to make sure I assembled the cable correctly? In order to save time on the motor, it only turns on when it takes a measurement.
      meisner OK, I have come across multiple articles, so I will try to follow this one. It sounds as thought using the Zephyr kernel is the recommended way to go? I was trying other paths since it seemed like Zephyr wasn’t the only option…maybe that was my first problem?
      It is. I just updated the documentation a bit to use the VSCode plugin. You should be able to build for the particle_argon target but I have no tested it. You do need an external programmer for it to work. (A nRF52 DK works fine)
        jaredwolff Got it. Can you send me a picture of your setup to make sure I assembled the cable correctly? In order to save time on the motor, it only turns on when it takes a measurement.
        Here’s the cable, sensor, Argon and AQW. Hopefully it shows what you needed.
        jaredwolff It is. I just updated the documentation a bit to use the VSCode plugin. You should be able to build for the particle_argon target but I have no tested it. You do need an external programmer for it to work. (A nRF52 DK works fine)
        I just placed an order for an nRF52 DK from Digikey … so when I get that, I will give it a try. In the meantime, review the page you mentioned and start assembling my Zephyr dev environment. Does the VSCode plugin also require a Zephyr cross-compile setup? I am referring to this page; https://docs.zephyrproject.org/latest/boards/arm/particle_argon/doc/index.html#programming-and-debugging
          meisner Here’s the cable, sensor, Argon and AQW. Hopefully it shows what you needed.
          Looks great!
          I did notice though that you’re trying to insert the Argon on the pins. You’re not going to make a good connection here and things will likely not work the way you expect. I suggest putting female headers on the AQW if you want to do this.
          (if all the pins are soldered, disregard. I simply can’t see the underside!)
          meisner I just placed an order for an nRF52 DK from Digikey … so when I get that, I will give it a try. In the meantime, review the page you mentioned and start assembling my Zephyr dev environment. Does the VSCode plugin also require a Zephyr cross-compile setup? I am referring to this page;
          It installs everything for you including the toolchain for ARM devices. So you should be good to go!
            Steve
                  Got it!
                      jaredwolff You’ll need to use Segger RTT for the particle boards.
                      OK thanks for all the help so far Jared, but I need to take a different path here. It seems like at many turns I need to buy another piece of HW or spend a good deal of time learning something I had no interest in. My goal was air quality info to be sent via MQTT. I have gone down so many tangential paths that this is taking too much time.
                      jaredwolff By the way here’s a link to getting half of the equation for Zephyr on an Argon:
                      Yes…even this article you cited is about replacing the stock firmware with CircuitPython … already saw this and determined, “Nope…don’t want to go down that path.”
                      Instead, I am looking at my first idea of using the AQW with an Adafruit Feather (with wifi support) and the Arduino IDE. I just need to understand the AQW interface & API better now.
                        meisner Instead, I am looking at my first idea of using the AQW with an Adafruit Feather (with wifi support) and the Arduino IDE. I just need to understand the AQW interface & API better now.
                        Got it. Sorry it’s taking longer than expected. I have a Huzzah32 here. Let me see if I can get the AQW code working on it. I’ll likely be able to get it working with Golioth fairly easily if you’re open to using something like that. They have a generous dev tier which is sufficient if you’re doing this for hobby purposes.
                        6 days later
                        OK…success!
                        I have had the AQW running (in the 3D printed enclosure you designed) for most of the day today using the HUZZAH32 and the Arduino IDE. Here’s the project:
                        https://github.com/smeisner/AirQualityWing
                        Let me know if you have any thoughts. This is the first version of the code, so improvements would be welcomed!! There is a “to do” list at the end of the README as well.
                          2 months later
                          Just added support for OTA upgrades, OLED display and telnet session for diags to the github project.
                          …in case anyone is following along. I have modified STL files to accommodate the display as well, but haven’t uploaded them yet. Coming soon.
