Also what type of system are you running this on? Windows?
Reconnecting LTE after Disconnect
PS D:\David\Wildlife\DeterGents\ZephyrToolsRepo\nfed\samples\mfw_update> pip3 install -r requirements.txt
Requirement already satisfied: pynrfjprog in c:\users\barli.zephyrtools\env\lib\site-packages (from -r requirements.txt (line 1)) (10.15.2)
Requirement already satisfied: future in c:\users\barli.zephyrtools\env\lib\site-packages (from pynrfjprog->-r requirements.txt (line 1)) (0.18.2)
I am running on WIndows, yes.
I’ve also verified the device is on COM3
Any ideas?
The mfw_update sample is programmed to the device
Can you confirm Barliesque?
Make sure your device is not in bootloader when running the script. Also make sure you don’t have any open serial connections to COM3.
Yes, mfw_update is programmed to the device. Using LTE Link Monitor, all AT commands fail – not sure if that’s expected for mfw_update. Pressing the RST button doesn’t cause any messages to appear there either. Before attempting the upload, I’ve made sure to close down anything that could have an open connection to COM3. The blue light is unlit, so not in bootloader mode.
Are you able to run at_client on that board? (And try again with AT commands?) The mfw_update firmware will not respond to AT commands.
Sorry, where do I find that?
I’ve run plenty of things on this board to know it works properly–most recently Blinky, which I installed just before the mfw_update.
The biggest thing is to confirm bidirectional comms over that USB to UART chip. You can find at_client in nfed/samples/at_client
Built and installed the at_client, then opened up LTE Monitor, pressed RST button and the terminal showed this:
2022-03-03T02:48:48.515Z DEBUG modem << õýÕ÷¯ÿõ÷õÕUý÷·Uÿõ÷÷ýßõõõõõõ÷õõ÷ÿõ½×õõý÷µÿÿõ÷·ÿßÿõýwõ÷õÿuõõÿõUuW÷uõõUu_UuõõWu]UõýUuWUuõõUuýõÝõWw}õuýWuÿõýõUw]UõõUwÿõßõUõýUõýWw}õõõýõ÷õ]ÝõUõõUõýWuõUõýUwõUõýUuõUõýWuÿ]]ÕõW÷õõÝõWw_uõõõýuWuõõõUuWuõõõýõõõõÝõWõ÷õõýõWWÿÕwuõwß__õU»uuu}õU÷WýUõõU÷õõ_}Uý}ÝõýõõõõýõÿuõõU*** Booting Zephyr OS build v2.6.99-ncs1-1 ***
2022-03-03T02:48:48.520Z DEBUG modem << The AT host sample started
Kind of gives me mixed messages there – looks like the at_client is working, but what’s the garbage before that? Is it maybe some random data that’s been sent as a test?
It’s the SPM image running at 1M baud. Change your BAUD to 1M to see what it says.
If you hit AT and press enter, does it respond?
jaredwolff If you hit AT and press enter, does it respond?
It responds to AT with OK.
jaredwolff Change your BAUD to 1M…
I thought it already was at 1M
For monitoring its 115200
For transferring its 1000000
How do I change the baud rate to 1M, and is that a potential fix for the problem of updating the modem firmware?
If you wanted to view that gibberish you’d have to use a different program to view the output. If you’re using VSCode Zephyr Tools you can invoke zephyr-tools-monitor to monitor a different BAUD:
❯ zephyr-tools-monitor --port COM3 --baud 1000000
Nevertheless, the update_mfw sample runs by default at 1000000 BAUD. You don’t need to change anything.
How old is the board you’re working with?
jaredwolff How old is the board you’re working with?
Purchased within the last year.
jaredwolff If you’re using VSCode Zephyr Tools you can invoke zephyr-tools-monitor to monitor a different BAUD
Ah ha!
Connecting..
Connected to COM3!
Flash regions Domain Permissions
00 03 0x00000 0x20000 Secure rwxl
04 31 0x20000 0x100000 Non-Secure rwxl
Non-secure callable region 0 placed in flash region 3 with size 32.
SRAM region Domain Permissions
00 07 0x00000 0x10000 Secure rwxl
08 31 0x10000 0x40000 Non-Secure rwxl
Peripheral Domain Status
00 NRF_P0 Non-Secure OK
01 NRF_CLOCK Non-Secure OK
02 NRF_RTC0 Non-Secure OK
03 NRF_RTC1 Non-Secure OK
04 NRF_NVMC Non-Secure OK
05 NRF_UARTE1 Non-Secure OK
06 NRF_UARTE2 Secure SKIP
07 NRF_TWIM2 Non-Secure OK
08 NRF_SPIM3 Non-Secure OK
09 NRF_TIMER0 Non-Secure OK
10 NRF_TIMER1 Non-Secure OK
11 NRF_TIMER2 Non-Secure OK
12 NRF_SAADC Non-Secure OK
13 NRF_PWM0 Non-Secure OK
14 NRF_PWM1 Non-Secure OK
15 NRF_PWM2 Non-Secure OK
16 NRF_PWM3 Non-Secure OK
17 NRF_WDT Non-Secure OK
18 NRF_IPC Non-Secure OK
19 NRF_VMC Non-Secure OK
20 NRF_FPU Non-Secure OK
21 NRF_EGU1 Non-Secure OK
22 NRF_EGU2 Non-Secure OK
23 NRF_DPPIC Non-Secure OK
24 NRF_REGULATORS Non-Secure OK
25 NRF_PDM Non-Secure OK
26 NRF_I2S Non-Secure OK
27 NRF_GPIOTE1 Non-Secure OK
SPM: NS image at 0x20200
SPM: NS MSP at 0x20020760
SPM: NS reset vector at 0x225c9
SPM: prepare to jump to Non-Secure image.Just restarted my system and tried again with the mfw_update. Still fails to program the device.
> python3 update_modem.py mfw_nrf9160_1.3.1.zip com3 1000000
[Probes.com3] [ModemUARTDFUProbe] Dll directory is C:\Users\barli\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64.
[Probes.com3] [ModemUARTDFUProbe] Find and connect to dfu dll
[Probes.com3] [ModemUARTDFUProbe] Using DFU dll at C:\Users\barli\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[Probes.com3] [ModemUARTDFUProbe] Load library at C:\Users\barli\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[Probes.com3] [ModemUARTDFUProbe] Library loaded, loading member functions.
[Probes.com3] [ModemUARTDFUProbe] Member functions succesfully loaded.
[Probes.com3] [ModemUARTDFU-com3] Initialize new probe.
[Probes.com3] [ModemUARTDFU-com3] Successfully opened port: com3@1000000,flow_control:none,parity:none.
[Probes.com3] [ModemUARTDFU-com3] {
"duration": 891,
"error_code": "Ok",
"operation": "open_uart",
"outcome": "success",
"progress_percentage": 100
[HighLevel] Probe initialization complete!
[Probes.com3] [ModemUARTDFU-com3] Check if provided file exists
[Probes.com3] [ModemUARTDFU-com3] Check if provided file can be read
[Probes.com3] [ModemUARTDFU-com3] Programming bootloader
[Probes.com3] [ModemUARTDFU-com3] Programming modem bootloader 72B3D7C.ipc_dfu.signed_1.1.0.ihex.
[Probes.com3] [ModemUARTDFU-com3] Extracting 13416 bytes from 72B3D7C.ipc_dfu.signed_1.1.0.ihex.
"duration": 0,
"message": "Calculating image size",
"operation": "upload_image",
"progress_percentage": 5
"duration": 1,
"message": "Uploading image to device",
"duration": 30004,
"error_code": "Timeout",
"message": "Image upload failed. Bad response from device",
"outcome": "fail",
[Probes.com3] [ModemUARTDFU-com3] Error during image file upload. Upload returned an error.
[Probes.com3] [ModemUARTDFU-com3] Failed to program bootloader file
[Probes.com3] [ModemUARTDFUProbe] Failed to program DFU package
[HighLevel] Failed programming the device.
[Probes.com3] b'An error was reported by NRFJPROG DLL: -220 TIME_OUT. \n[Probes.com3] [ModemUARTDFU-com3] Error during image file upload. Upload returned an error.\n\textra: [Probes.com3] [ModemUARTDFU-com3] Failed to program bootloader file\n\textra: [Probes.com3] [ModemUARTDFUProbe] Failed to program DFU package\n\textra: [HighLevel] Failed programming the device.'
[Probes.com3] [ModemUARTDFUProbe] Uninitializing ModemUARTDFU probe at serial port com3.
[Probes.com3] [ModemUARTDFU-com3] Sending device reset request
[Probes.com3] [ModemUARTDFU-com3] Sending reset request to device.
[Probes.com3] [ModemUARTDFU-com3] Closing connection to mcuboot device
[Probes.com3] [ModemUARTDFU-com3] serial port com3 closed.
"duration": 1,
"error_code": "Ok",
"operation": "close_uart",
[HighLevel] Done.
File "D:\David\Wildlife\DeterGents\ZephyrToolsRepo\nfed\samples\mfw_update\update_modem.py", line 43, in <module>
File "D:\David\Wildlife\DeterGents\ZephyrToolsRepo\nfed\samples\mfw_update\update_modem.py", line 26, in run
modem_dfu_probe.program(modem_firmware_zip)
File "C:\Users\barli\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\HighLevel.py", line 388, in program
pynrfjprog.APIError.APIError: An error was reported by NRFJPROG DLL: -220 TIME_OUT.
extra: [HighLevel] Failed programming the device.Help?
Since you’re able to communicate with the device it’s probably not a USB issue. Just to confirm, you can flip the orientation of your USB connector (turn it 180 degrees from the way you were using it) to see if that makes an improvement.
Do you only have one board to try this on Barliesque ?
jaredwolff Just to confirm, you can flip the orientation of your USB connector
With this device and USB cable I was able to install the Blinky and client_at projects, as well as upload the mfw_update app itself. Flipping the USB connector had no effect.
jaredwolff Do you only have one board to try this on
I have several devices on hand. I’ve just switched over to one of those and hit the same problem. This device is on COM11, so I used Zephyr Tools: Setup Newtmgr to switch to COM11, bauderate 1M. I installed the mfw_update app. Then used python3 update_modem.py mfw_nrf9160_1.3.1.zip com11 1000000 to attempt the upgrade. Same thing happens.
I now have a second computer I’m in the process of getting set up for modem firmware updates. I’ve run into some problems getting computer #2 setup properly: The nfed folder doesn’t appear in VS Code, giving me no way of switching over to the mfw_update project.
I’ve got one computer with which I can install the mfw_update. So I thought maybe I could use the other to perform the update. Here’s what happened there:
> python3 update_modem.py mfw_nrf9160_1.3.1.zip com9 1000000
[Probes.com9] [ModemUARTDFUProbe] Dll directory is C:\Users\usaf\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\pynrfjprog\lib_x64.
[Probes.com9] [ModemUARTDFUProbe] Find and connect to dfu dll
[Probes.com9] [ModemUARTDFUProbe] Using DFU dll at C:\Users\usaf\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[Probes.com9] [ModemUARTDFUProbe] Load library at C:\Users\usaf\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[Probes.com9] [ModemUARTDFUProbe] GetErrorInfo failed.
[Probes.com9] [ModemUARTDFUProbe] Failed to load dll at C:\Users\usaf\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
[HighLevel] Failed while initializing probe.
[Probes.com9] b'An error was reported by NRFJPROG DLL: -151 NRFJPROG_SUB_DLL_COULD_NOT_BE_OPENED. \n[Probes.com9] [ModemUARTDFUProbe] GetErrorInfo failed.\n\textra: [Probes.com9] [ModemUARTDFUProbe] Failed to load dll at C:\\Users\\usaf\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python39\\site-packages\\pynrfjprog\\lib_x64\\NRFDFU.dll.\n\textra: [HighLevel] Failed while initializing probe.'
File "C:\Users\usaf\ncs\v1.7.1\nfed\samples\mfw_update\update_modem.py", line 43, in <module>
File "C:\Users\usaf\ncs\v1.7.1\nfed\samples\mfw_update\update_modem.py", line 25, in run
with HighLevel.ModemUARTDFUProbe(api, uart, baudrate) as modem_dfu_probe:
File "C:\Users\usaf\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\pynrfjprog\HighLevel.py", line 591, in __init__
pynrfjprog.APIError.APIError: An error was reported by NRFJPROG DLL: -151 NRFJPROG_SUB_DLL_COULD_NOT_BE_OPENED.
extra: [Probes.com9] [ModemUARTDFUProbe] Failed to load dll at C:\Users\usaf\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.9_qbz5n2kfra8p0\LocalCache\local-packages\Python39\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
