I assume you’re using an nRF9160 Feather?
Tracker sample questions
jaredwolff Yep - purchased just a week or so ago.
Hmm I’ll have to get back to you. Not sure why it’s not working for you.
I assume you haven’t modified any of the jumpers on the underside of the board? Also make sure you don’t have anything connected to D3 since that is shared with the interrupt pin of the LIS2DH12TR
Only thing I’ve done to the board since taking it out of the packaging is attach the antennas and insert the SIM. Nothing attached to any pins, and no modifications of any jumpers.
For repro purposes, I created a brand new folder, and followed everything step by step from here (https://www.jaredwolff.com/nrf9160-feather-on-golioth/) and got exactly the same results… GPS publish on initial position fix, but nothing triggering at an interval, and nothing triggering by movement. All that happens is the golioth client expires after about 10 minutes and reconnects.
Doesn’t really help, but I also tried a fresh install of the extension/tooling and repo on a mac (previous builds were on a PC) and got the same result.
Ok let me look into it. Must be a big somewhere.
@mwgustin sorry for the delay on this!
Turns out, I changed the code so JMP3 was the interrupt pin. By default that guy is open on the bottom of the board. If you short it with a blob of solder, you should get wake up events which trigger GPS. In that sample, the only thing that starts GPS is motion but you can create your own timer and invoke the app_gps_start
function or make your own customizations to app_gps.c
as you see fit.
Hope that helps. Let me know if you have any other questions!
Thanks so much for the help! I’ve added the bridge on JMP3 and I’m making a little progress… I am able to get motion events shortly after start up while the GPS is looking for a fix, but not once it finds a GPS fix.
I added an app_motion_reset_trigger_time call to the APP_EVENT_ACTIVITY_TIMEOUT and that lets me get a motion event after the initial GPS fix, but when the APP_EVENT_MOTION_EVENT triggers, the app_gps_start call returns a -120 error (which I believe means it’s already started). I’m going to go down the path of setting up a polling timeout, but I’m gonna guess I get the same -120 response in that as well… do I need to call the app_gps_stop function somewhere? Or will that cause the GPS to need to fully reacquire a position?
mwgustin hmmm. Maybe it wasn’t stopped which means it should acquire another fix based on the CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL
interval. You can search for this in your build folder to see what it’s set to. I believe this value is in seconds.
You can also stop it and restart but it may request the AGPS data again.
Got the polling working! Thanks so much for the help. It was a few things…
- the value was being set in the Pyrinas.conf file which I don’t believe is being used by default (since the default backend is golioth). Added it to the golioth.conf
- the value’s default setting was 10 hours (36,000 seconds). Changed that to 30seconds
- The gps_config in app_gps had the nav mode set to GPS_NAV_MODE_SINGLE_FIX which will search and then stop once it finds a fix. I updated it to GPS_NAV_MODE_PERIODIC so that it will respect the interval timing.
Those 3 changes got things working! Again - super appreciate all the help.
One last question for you - I noticed you rolled your own event manager for the main portion of the app utilizing the internal msgq rather than using the built-in zephyr event manager? Is there a particular reason for that?
mwgustin Those 3 changes got things working! Again - super appreciate all the help.
Excellent!
It just made sense at the time. I know Nordic built one but wasn’t aware of a Zephyr specific one. There’s so much in Zephyr that it’s hard to cover all the ground! If you don’t mind sharing where that implementation is that’d be cool to see and play with.
