Hello,
I am having some issues connecting to my cloud server using the HTTPS client. The difference here being the server is not using a certificate and is using a JWT in the authorization header in of the HTTP GET. The server is using TLS1.2, but when I export the ciphersuite used, it returns 0xffffffff and errors out in the connect() (failed with error:95). If I remove TLS, I get a timeout with connect() (failed with error:22).
To get the ciphersuite, I am using the following code:
rtn = setsockopt(fd, SOL_TLS, TLS_CIPHERSUITE_USED, 0, 0);
if (rtn) {
printk("Ciphersuite Used: %x\n", rtn);
Any thoughts on this?
Here is the description of TLS_CIPHERSUITE_USED:
`/** Read-only socket option to read a ciphersuite chosen during TLS handshake.
  • It returns an integer containing an IANA assigned ciphersuite identifier
  • of chosen ciphersuite.
    #define TLS_CIPHERSUITE_USED 4`
    cchoi22915 the modem firmware only supports certain cipher suites. I know I had some issues with HTTPS originally because the Rust code I was using supported only newer more require cipher suites. Since modem firmware 1.3.1, the modem firmware supports more modern/compatible cipher suites.
    I would double check to make sure that your HTTP connection works before moving to HTTPs. That way you can rule out any DNS issues and connection issues.
      jaredwolff Hi Jared, I am trying to update my modem firmware, but I am running into issues getting the firmware to execute. I have followed all of the instructions on the readme for mfw_update, but it is failing with extra: [Probes.COM5] [ModemUARTDFUProbe] Failed to load dll at C:\Users\Chris\AppData\Local\Packages\PythonSoftwareFoundation.Python.3.10_qbz5n2kfra8p0\LocalCache\local-packages\Python310\site-packages\pynrfjprog\lib_x64\NRFDFU.dll.
      I am not sure what other steps I can take to get this running as NRFDFU.dll does not seem to exist. I made a separate post on this issue, but I cannot seem to resolve it.
