@jaredwolff I’ve recently run into this exact issue.
Repro:
I have a previous project running on nrf-sdk 1.7.1. I had built the software from CLI using west and flashed using newtMgr.
Once flashing my software, I experience the same behavior of the device turning off once disconnected from USB. No modifications to the jumper.
I was able to resolve this by flashing the hex you linked above. Can you clarify what modifications are needed to be done to a stock Zephyr project bootloader to be compatible with the v4 feather? Is there a patch file / script that can be run to make these changes?
It looks like modifications where made here https://github.com/zephyrproject-rtos/zephyr/commit/d7405647dfc15f8b04fc1e2a49ac33474a066330 which enable ps_en
