Hello Circuit Dojo Community,
I’ve run into a strange issue in Zephyr RTOS and specifically the accelerometer sensor driver code from STMicro, located in zephyr/drivers/sensor/iis2dh/iis2dh.h. While I may not do so long term, I would like to declare an instance of iis2dh_device_config as defined in https://github.com/zephyrproject-rtos/zephyr/blob/main/drivers/sensor/iis2dh/iis2dh.h#L49.
I would like to use an instance of this structure, with its i2c member declared and available at run time. But I’m not able to get the pre-compile time test about iis2dh.h line 50 to evaluate to ‘true’.
The problem I have encountered today is that the macro DT_ANY_INST_ON_BUS_STATUS_OK(i2c) evaluates to false in my present project. Strangely, I have left prj.conf Kconfig symbols for I2C, IIS2DH and related enabled. I have also left device tree overlay for my target board, an lpcxpresso55s69_cpu0, also as these files were when I built against Zephyr 3.1.0.
( I have moved forward from Zephyr 3.1.0 to 3.2.0 for real time clock support, plus a few other changes. )
Excerpt of sensor related Kconfig enables in my prj.conf:
CONFIG_SENSOR=y
CONFIG_KX132_1211=y
# 2021-10-16 SAT . . . note this alone does not inform `cmake` where
# to find STMicro's driver sources in sdk-nrf modules/hal/...:
CONFIG_IIS2DH=y
CONFIG_IIS2DH_RANGE=0
CONFIG_IIS2DH_ODR=0
Excerpt of DTS overlay file:
stmicro_sensor: iis2dh@19 {
compatible = "st,iis2dh";
reg = <0x19>;
label = "IIS2DH";
Excerpt from build/zephyr/zephyr.dts:
compatible = "nxp,lpc-i2c";
reg = < 0x8a000 0x1000 >;
interrupts = < 0x12 0x0 >;
clocks = < &syscon 0x4 >;
clock-frequency = < 0x186a0 >;
#address-cells = < 0x1 >;
#size-cells = < 0x0 >;
pinctrl-0 = < &pinmux_flexcomm4_i2c >;
pinctrl-names = "default";
mma8652fc: mma8652fc@1d {
compatible = "nxp,fxos8700", "nxp,mma8652fc";
reg = < 0x1d >;
int1-gpios = < &gpio1 0x13 0x1 >;
kionix_sensor: kx132_1211@1f {
compatible = "kionix,kx132_1211";
reg = < 0x1f >;
label = "KX132_1211";
reg = < 0x19 >;
label = "IIS2DH";
Note from this excerpt of the build artifact file zephyr.dts, device node flexcomm4 is compatible with “nxp,lpc-i2c”, and has a node property of status set to “okay”. If I read Zephyr Project documentation correctly, at https://docs.zephyrproject.org/latest/build/dts/api/api.html#c.DT_ANY_INST_ON_BUS_STATUS_OKAY, these properties seem sufficient to produce a final device tree file with a node which will pass the test on line 49 of STMicro’s iis2dh.h header file in Zephyr’s 3.2.0 release.
One final code excerpt from [custom_zephyr_app]/build/zephyr/include/generated/devicetree_generated.h, these are the final lines in this relatively long compile-time artifact:
10530 * Bus information for status "okay" nodes of each compatible
10531 */
10532 #define DT_COMPAT_nxp_lpc_i2c_BUS_i2c 1
10533 #define DT_COMPAT_nxp_fxos8700_BUS_i2c 1
10534 #define DT_COMPAT_nxp_mma8652fc_BUS_i2c 1
10535 #define DT_COMPAT_kionix_kx132_1211_BUS_i2c 1
10536 #define DT_COMPAT_st_iis2dh_BUS_i2c 1
10537 #define DT_COMPAT_zephyr_sdmmc_disk_BUS_sd 1
I’m wondering how these lines can build and appear in this intermediate file, and that macro does not detect that an IIS2DH sensor is on a valid, enabled I2C bus?
Have I overlooked some basic or other critical code in the Kconfig and or device tree parts of my project? Has anyone else encountered similar issue?
One final note: the project compiles against Zephyr 3.1.0 and runs, talking over I2C to the IIS2DH sensor on the bench there. Can also talk to a KX132 accelerometer attached to the same board, firmware, and same I2C bus. Both sensors respond, so hardware checks out as working. Problem seems to be in Zephyr build tools’ search for “any instance on I2C bus, with status of okay”.
