SteveD0 “nix the tag connect and use the standard 10-pin connector”.
I’m talking about V2 adjustments for the future. 🙂
SteveD0 To the second point, if I only need 4 connection, can I use 4 dupont cables to connect between the 4 header locations on the programming board and 4 stacking header locations on the nRF9160?
How are you stacking the boards? If you stack the nRF9160 Feather on top then you don’t have to worry about accessing it. Most Adafruit boards come unsoldered so you can add a female header instead of a male. Or, alternatively, use a doubler or tripler.
Back to one of my questions earlier, is there an issue stacking (or connecting via a doubler, etc.) two MCUs as the Rx and Tx are connected to the same and not reversed to each other?
    SteveD0 There you go! The more the merrier. Remember as you start using these boards you need to make sure other signals play nicely with each other. I’ve been working with a Particle Xenon + nRF9160 Feather an I had to cut the battery trace between the two. The battery chargers were not happy with each other. 😇
    2 months later
      K2AAE Yea exactly. If you’re nice to it, it lasts a good while. Pays for itself for big projects in no time. 😀
      8 days later
          a month later
          Any ideas?
            6 days later
            rbrtwtrs I have been going back and forth on this. It’s rough to add on this design. Did it with another one that’s coming out and there was enough room. 😀
              I do realize though that some folks don’t have TC cables and that was a bummer from a debugging perspective. Most folks can do most through the usage of the bootloader. I find myself using newtmgr more often than searching for my nRF9160 DK and TC cable to program.
                6 days later
                I noticed you have stock again, I was going to order another board after killing mine, you were OOS, good thing, I discovered I’d put the wrong Hologram SIM back in after my Verizon SIM disaster… The AT+CESQ doesn’t seem to work unless your SIM and Device are registered… ::
