      a month later
      Any ideas?
        6 days later
        rbrtwtrs I have been going back and forth on this. It’s rough to add on this design. Did it with another one that’s coming out and there was enough room. 😀
          I do realize though that some folks don’t have TC cables and that was a bummer from a debugging perspective. Most folks can do most through the usage of the bootloader. I find myself using newtmgr more often than searching for my nRF9160 DK and TC cable to program.
            6 days later
            I noticed you have stock again, I was going to order another board after killing mine, you were OOS, good thing, I discovered I’d put the wrong Hologram SIM back in after my Verizon SIM disaster… The AT+CESQ doesn’t seem to work unless your SIM and Device are registered… ::
            Thanks for the feedback @K2AAE. And yep back in stock. The parts you mentioned have been fun to procure 😭
              4 months later
              jaredwolff Finally found some CP2102! Mouser just got some, only 1K but I got a few. Quote of 52 weeks for some parts….
