I’m trying use the pcf85063a driver in a Zephyr v3.2.99-ncs1 build. The driver reports that it failed to get the pointer and Zephyr reports that the device is not ready. How can I properly initialize this device?
prj.conf
CONFIG_DEBUG=y
# Using C
CONFIG_NEWLIB_LIBC=y
# Enable NRF Modem
# CONFIG_NRF_MODEM_LIB=y
# CONFIG_NRF_MODEM_LIB_SYS_INIT=y
# Setup networking
# CONFIG_NETWORKING=y
# CONFIG_NET_NATIVE=n
# CONFIG_NET_SOCKETS=y
# CONFIG_NET_SOCKETS_OFFLOAD=y
# CONFIG_NET_SOCKETS_POSIX_NAMES=y
# Config Heap and Stack size
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_HEAP_MEM_POOL_SIZE=40960
# Setup LTE
# CONFIG_MODEM_KEY_MGMT=y
# CONFIG_LTE_LINK_CONTROL=y
# CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
# AT host library
# CONFIG_AT_HOST_LIBRARY=y
# CONFIG_UART_INTERRUPT_DRIVEN=y
# Bootloader
#CONFIG_MCUBOOT_IMG_MANAGER=y
# Enable I2C
CONFIG_I2C=y
CONFIG_I2C_NRFX=y
# Enable CJSON
#CONFIG_CJSON_LIB=y
# Enable Counter
#CONFIG_COUNTER=y
# Date Time library
#CONFIG_DATE_TIME=y
# Enable External RTC
CONFIG_COUNTER=y
CONFIG_PCF85063A=y
# Enable Logging
CONFIG_LOG=y
CONFIG_LOG_MODE_IMMEDIATE=y
overlay
&i2c1 {
compatible = "nordic,nrf-twim";
zephyr,concat-buf-size = <256>;
pinctrl-0 = <&i2c1_default>;
pinctrl-1 = <&i2c1_sleep>;
pcf85063a: pcf85063a@51 {
compatible = "nxp,pcf85063a";
reg = <0x51>;
lis2dh: lis2dh@18 {
compatible = "st,lis2dh";
reg = <0x18>;
irq-gpios = <&gpio0 29 GPIO_ACTIVE_HIGH>;
disconnect-sdo-sa0-pull-up;
main.c
#include <stdlib.h>
#include <stdio.h>
#include <inttypes.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/util.h>
#include <zephyr/drivers/counter.h>
#include <zephyr/drivers/gpio.h>
#include <zephyr/drivers/i2c.h>
#include <drivers/counter/pcf85063a.h>
#define I2C1_NODE DT_NODELABEL(i2c1)
#define I2C1_NAME DEVICE_DT_NAME(I2C1_NODE)
#define I2C1 DEVICE_DT_GET(I2C1_NODE)
#define RTC_NODE DT_NODELABEL(pcf85063a)
#define RTC_NAME DEVICE_DT_NAME(RTC_NODE)
#define RTC DEVICE_DT_GET(RTC_NODE)
LOG_MODULE_REGISTER(main, LOG_LEVEL_DBG);
//#define MY_I2C "I2C_1"
//const struct device *i2c_dev;
const struct device *rtc;
static void rtc_init() {
/* Get the device */
rtc = device_get_binding("pcf85063a_51");
LOG_INF(I2C1_NAME);
LOG_INF("i2c1 status: %s", DT_PROP(I2C1_NODE, status));
LOG_WRN("i2c1 is ready: %s", device_is_ready(I2C1) ? "true" : "false");
LOG_INF(RTC_NAME);
LOG_WRN("pcf85063a is ready: %s", device_is_ready(RTC) ? "true" : "false");
if (rtc == NULL) {
LOG_ERR("Failed to get RTC device binding");
return;
LOG_INF("device is %p, name is %s", rtc, rtc->name);
int err = counter_start(rtc);
if (err) {
LOG_ERR("Unable to start RTC. Err: %i", err);
void main(void) {
k_msleep(1000);
rtc_init();
Output
Connected to /dev/ttyUSB0!
[00:00:00.411,499] <err> pcf85063a: Failed to get pointer to i2c@9000 device!
[00:00:00.419,311] <inf> regulator_fixed: nrf-ps-en sync: 0
[00:00:01.429,351] <inf> main: i2c@9000
[00:00:01.433,563] <inf> main: i2c1 status: okay
[00:00:01.438,629] <wrn> main: i2c1 is ready: true
[00:00:01.444,091] <inf> main: pcf85063a@51
[00:00:01.448,699] <wrn> main: pcf85063a is ready: false
[00:00:01.454,681] <err> main: Failed to get RTC device binding
