is it necessary to use the TC-2030 CTX Tag Connect?
It isn’t available in my country and importing the cable will cost double the price of what it originally costs.
for the firmware update instead of a nrf53-DK.
harshitreddy is it necessary to use the TC-2030 CTX Tag Connect?
Only if you want to program with an external programmer.
harshitreddy and can I use this:
I’m not sure and can’t guarantee it. I can only confirm what I’ve tested personally. You’ve probably already seen it but the notes on that particular subject are here.
jaredwolff I guess I can use a regular MOLEX 10 pin connector.
This is just a one time operation where I want to update the MCUBoot Firmware and the programming after that I plan on using the USB port. So I won’t have any use for the external programmer after the flashing the firmware.
I hope I got the process right?
